is that all pete? you didnt spend much time out my way eh?
sweet
south isnt that bad - what suburb?
christie downs or some shit. shouldnt be any worse than craigmore. :P
also, man that chick in your avatar makes me crack a phat
yup, same, thats why i put it there, you know, sharings caring.
i live in port noarlunga which is pretty much down the road from christies beach and downs.
some parts isnt amazing but like you said, cant be worse then craigmore :happy:
where abouts in chritie downs you living?
Put this over the airbag sticker
I don't know whether to tisk dissaprovingly or piss my self laughing
Theres heaps more.. some rather lame.. such as the V8 one at the bottom
Edited by Stagstock
hmmm steve is closest lol
i will provide the case, but have nfi what the best parts are, computer stupid you see.
Can do something for u if u want. I'll be getting a new i7 based system with 6 gigs of low latency ram, 15k rpm SAS drive, nice motherboard, entry level vidcard, 2 terrabyte server drives... etc
around $1.5k worth for something like that. depends what u want the system for and how much u wanna spend. its easy stuff tho
-D
i spent a few seconds trying to figure out why this sounded familar.
then i remembered the wheels, and sizes are exactly the same as ben was gonna run as track wheels.
another coincidence? gonna get some fat viennas as show wheels too?
:P
shutup dave you smartarse :happy:, i was looking into other options anyway. wasnt left with a lot considering the rear guards have been massacred that bad.
(editing AFTER my computer shat itself)
1. hunt for second hand wheels in low offsets
- pros: sick wheels, jdm appeal, extremely stupid width and offsets
- cons: chance of finding something in as low an offset as i need, buckleys to none, and i would need to run spacers
2. buy new jap wheels
- pros: wheels in good width, offset and in my stud pattern
- cons: limited range, price is absolutely rediculous, need spacers more than likely
3. get ROH modulars made
- pros: wheels will fit without spacers, will be exactly what i want
- cons: takes a while for them to be made (2 odd months lead time)
considering it was 5k for meisters, or around the 2k mark for 1pr front and 2pr rears, i think i know what wins while trying to build on a semi-budget
Edited by Matty 31
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
