The Sa Wasteland
Cubes
 Share
Also where can you buy perspex from?
cheers
Give Kinda Plastics a call, should be able to sort you out for a good price
Kinda Plastics Fabrication P/L 1B 47 O.G. Rd Klemzig SA 5087
ph: (08) 8367 6444
to quote cara before in an msn discussion
MissR34 says:
the heater thingo its like some reverse cycle thingo i thing it has been on its periods latley cause it aint been working properly making lots of noise but not blowing anything hahahaha
Matty T: Now with enough lift to drive over a Toyota Prius says:
ROFLMAO
sounds more like a lesbian :D
tell her to get off msn an load the damn pics up already, i want to see how they actually turned out on something other than a piss ant camera screen... :D
i live in port noarlunga which is pretty much down the road from christies beach and downs.
some parts isnt amazing but like you said, cant be worse then craigmore :D
where abouts in chritie downs you living?
seems like most of the 31 club lives down south. :)
bain street, apparently.
it lives on sau...............
yeah they came out awesome! thanks heaps for that dude!
for those that want to know what im going on about:
Here's me showing some leg:
and me pretending to be naughty lol
Guest CleanAndSimple
anyone done the thermo fans and removed the clutch fan? looking into it. as i think my clutch fan is dying.
any points in the right direction would be chilled.
 Share
    • That’s a great deal and I would jump on it if you were closer. Melbourne is a bit of a hike for me though unfortunately
    • I wonder if there is much to tell without knowing where the bolts where bought from. If it comes from Amazon or similar all bets are off. Can't trust them. And I fear not everybody knows that. Wasn't it @TurboTapin who ended up with the fake fuel lines recently? The submersible ones which very much weren't submersible at all. It kind of applies to everything nowadays. Doesn't matter if it's hardware or electronics. The fancy camera might have internals swapped out for cheap knockoffs. The hard drive will report a certain size but not actually be able to write it all. Shit like that. A bit depressing but the reality is you really have to be weary of where and how you buy stuff
    • My guess is, cheap rods, came from a site selling lots of cheap things, and likely a lot of knock off stuff.   I get doing a cheap build, but I don't get doing a huge dollar build, and then skimping on something even like the rods, and likely the bolts to go with it, especially if heaps of stuff had to be fabricated!
    • Today myself and a mate tracked a fuel pump issue down to this amazing piece of workmanship in the fuel cradle loom. Covered by conduit and electrical tape. so now we should be moving onto the first fire once this is corrected. 🤞🤔
    • 1000% percent the looks just aren't visible, I was shocked when i found out the the only thing holding the OEM diff ( rear side ) is one stud was can easily crack when trying to launch the car or really beating on it, hence why this brace connects to the subframe/control arms and even includes a fancy jackpoint, With the forced induction route, I would have quickly launched the diff out the back of the car without this upgrade. The Z1 and GK tech don't offer the same "cool" look so to speak.
