ha! cool, what do you plan to do in this hugeee field?
I currently do web design and graphics :] heaps of fun and very easy going!
Heh yeah Damo, what way do you want to clusterf**k your brain? :D
<-- Linux System Engineer. Fun stuff.
-D
hmm, not too sure about the job, bets to make a portfolio (a few play around websites and show off what you got )
Im not very good at my job tho, only self taught and did it from yr 9 to 12...
but its fun! you should enjoy it! and if you get days like today (slow day) you can watch movies (Anchorman for me atm) lol
well i currently maintain my works website using a program thats pretty much halfway between notepad and word, not something id stick in my portfolio
thats worth putting in if you want to do webdesign. understanding HTML and XML and all the various standards is pretty much mandatory. Even better if you can get into Ruby On Rails, Perl, Php, SQL and the like... best to do some research and speak to a few people in different professions to find out what u want to do. Webdesign can vary from picture manipulation, to doing backend programming on large databases -very very different roles but come under the same banner.
-D
-D
SQL would come in handy with my current job, could write our own reports for the database instead of contacting Melbourne to get them done!
any of these worth doing? http://www.seeklearning.com.au/short-cours...phic-design.asp
Next week i should be attempting some XAML code, doubt it will go well... but we do need a new media player, and the ones ive seen look very nice!
theres alot of programs that make databasing easy (connecting it to your website etcetc)
my problem is, web standards.. :D stupid IE..
Don't know. are you any good with graphics manipulation already? Most short courses only teach you basic photoshop stuff, to be a decent web based graphical designer you'd be wanting to do at least a years worth of training - possibly at uni aswell...
Speak to some webdesigners first and go from there... SQL is programming, Graphic Design is as far away from programming as you can get. It all depends on your mindset, and whether or not you would enjoy either.
-D
the latest craze in vehicular modifications.
literal horsepower in the engine.
(look somewhere over there ------> if youre soft)
Hungry little fella?
Edited by RubyRS4
    • I didn't think about how a circle works before, dumb.  Before, I had .9mm restrictor bolts but I can't use these cause they were shorter aluminium bolts that just tear off their threads when tightening since the OEM lines are thicker than the shitty braided one that was installed previously. Now I use longer 1mm stainless steel restrictor bolts. I think the difference will not affect the health of the turbos, but I guess I'll have to drill out the main feed bolt as I agree multiple restrictions sound dodgy. The one that was installed with the braided line was just too short, but completely without a restrictive hole.
    • Tomei or Nitto, don't use the OEM one or Cosmetic ☺️
    • After cleaning up a rusty cooling system in a 33 gtst that's been sitting for years it seems to have cleaned out the head gasket too haha. It seems the Tomei metal gasket works without machining surfaces? Or put oem? Also should put an oil restrictor while the head is off? Thanks
    • Thanks, I definitely saw the more expensive options from Crank and driveshaft shop. Thank you for the D-max option.  Still hopeful someone has an OEM out of the box option I found that the 300zx NA Left drive shaft is a good match for the Right on the R33. https://www.gsplatinamerica.com/product/ncv53040 Just need to find Left CV for the R33, I cannot find any <=22" axles.
