im getting one too. :P
id heat wrap it, but thats just cause im lazy and cant be arsed with heat shields.
I thought you got the GK dump, or did you end up sending it back?
I have access to a fair amount of the adhesive reflective heat shield material that I figure I can stick to anything that might be affected if need be. I can't see myself upping the boost or driving it hard enough to warrant heat wrap.... but if there's something I might have overlooked...
I'm going to be getting a AM dump front pipe as soon as Andrew has made one for me, do you guys think it needs heat wrap... keeping in mind I run stock boost?
Suppose it depends whether you're running a pod or an enclosed CAI. If the later, probably no real need but if you're running a pod, may make a difference in summer by removing some of the under bonnet heat.
Again, a wise choice :P Considering getting a whole system?
No. I have an Apexi N1 Evolution cat back I bought from an interstate forum member in December last year collecting dust in the garage, I'll get this fitted when I get the dump/front and cat fitted.
No pod SLED, factory intake with apexi panel filter.
still got that pos... sold the front pipe, still selling the dump pipe. couldnt be arsed arguing for a refund, so im just selling the shit. luke called andrew the other day while he was helping me with my turbo and i decided id bite the bullet and buy an AM dump and front.
ns? :laughing-smiley-014:
nothing like a real cornish pasty Stevie
depends on what u call real
the cornish pasties they sell arent quite authentic, being that theyre just meat and vege mix in a shortcrust
a true cornish pie (as was made for the miners) would be comprised of a meat section and a fruit section (representing the main course and the desert respectively) and the end would be a big knurled section of pastry that would be thrown away (since the miners hands would be covered in coal soot)
you might have the forward section made of beef and peas or something like sausage and potato, and the second section would be diced apricots or plum pie... usual cornish fare, but baked into an all-in-one snack
trivia 101. you may leave cash donations on my door.
-D
into these cornish-pasty.jpg now are we :P
Thats a samosa dude.
I have a rad samosa recipe, with ground beef, tumeric, cumin, garam masala, salt n pepper, garlic and a pastry made from wheat and butter, deep fried to orgasmic perfection
whoever ur wife is, she wishes she had a dohmar right about now
-D
-D
for the record,
i aint making u no frikin cornish pasty,
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
