female siamese fighter fish are not as attractive as males, and can be kept together,
males are the aggressive ones, and much better to look at..
damo, chuck him on top of your dvd player/set top box/something similar, this will help keep
the water temp up, alternatively, grab a heat matt from a reptile store and sit him on that.
EDIT: alternatively, stop being a pussy, and get a real set up, African Cichlids ftw
OR better yet, dont be a cheap arse and go and spend $20 getting a 15 watt immersive aquarium heater
it aint rocket science ;P
-D
I have one at home! They DONT like the cold, their metabolism slows right down, they barely eat, sleep all the time. Need to keep the water at at least 22 degrees, which im finding hard at the moment. Also, dont just feed them the little flake feed from the pet store, they need those freeze dried small dead worms as well, after all, they are carnivores.
All good, i purchased high protein betta food, water conditioner and ager.
Our office is warm and he is pretty active at the moment
Haha i got one too....i should change my fish's name to Lee :whistling:
my fish is called Jackie.....after Jackie Chan obiviously.....he is a fighter
your spot on Damo about maintaining the temp of the water and cleaning it every 3-4 days lol
Do it! or buy a second one and call it Chan. I need a another one to call Lee!
sounds like someones got a potential expensive repair to do, what happened to it?
god i hope not lol
just the 4wd light has been coming on for some time now...attessa error code 21
its ment to be the TPS which i have reaplced with a couple 2nd hand ones but the light still stays on so yer just want it fixed
anyone here know what it could be??
cheers
god i hope not lol
cheers
if you've replaced the TPS probably gonna be a bad wire or a miscalibration. apparently it does happen
http://www.gtr.co.uk/forum/109608-how-do-i...ion-sensor.html
-D
so, been working on the 200. pulled the spoiler off.
and something appears to be missing here...
and this is why its missing, old vs new;
pulled the turbo off, took a bit of f**king around, in pretty good condition, no shaft play at all. seems the oil i thought was leaking out the front seal is just from the rocker cover (blowby?), so i think ill be investing in a catch can soon.
see the thing is dave your running a SR not an RB :whistling: hehe
you can keep your lump of cast iron. :D
Good to see you finally got her off Dave! You need a hand putting her all back together once I get the dump for ya?
yeah, its been uh... interesting. ha. yeah, could use a bit of help putting it all back together. i shall provide beer for afterwards.
(and let you drive it of course)
Well i know it starts so im happy. Just need to get it all back tomorrow night, take it for a drive around the block and see if the new semi's rub on the guards. Knowing my luck they will. Nissan probably wont have the belts in stock to.
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
