The Sa Wasteland
Cubes
 Share
yeah when my first core went i bought the whole box from the wreckers and Luke and I pulled my whole dash out using the guide on here but i had the core go another 2 times so all up broke 3 cores
when my 2nd core broke i took it too synergy because i doubted my work and i wanted the insurance of if it broke again they would have to pay for it because they sourced the core also, then that core broke and i took it back for warranty work and few other things like blender motor as well
yeah i know some people feel hard done by them but with me i couldn't speak more highly of Rob for price and easy of getting my car in there
hey guys letting you know my turbo shat itself at mallala yesterday ate a bearing has anyone had this happen to their gt3076r?
anybody have any footage of mallala yesterday I had the white r33 gtst with slicks and dump pipe under the car.
cheers
cheers
im uploading some footage from my phone, its not the best though.
Cool, thanks... I feel a little better about it now :(
if you get stuck, gimmie a call cause I've done this before on the 32. Having the dash out makes it easier but u can do it without the glovebox like steve said (just means its a little tricky to unclip the actuator from its mount.
If its anything like mine, it'll just be dry solder joints (like the guide steve posted a while back shows). Hope you're handy with a soldering Iron...
-D
-D
Thanks, I'm going to wait a couple of weeks until I complete the house move then have a go at it..... Yeah I'm pretty bloody good with the soldering iron now after about 8 channels of mic preamp, around 4 compressor/limiters and a couple of EQ's and then many many PSU's...LOL!
lol, f**k replacing 3 cores!
when my old 33 blew its first core, i just bypassed it before the fire wall lol
oh well, it didnt end up seeing another winter anyway.
anyone know any chick bike riders?? a friends gota pink bike for sale for 4k its a 250cc or whatever the L plater limit is. Think its a suzuki but can find out if anyone knows someone after a pink bike
all minto, she hardly ever used it and everything got rebuilt when she bought it. she wasted her money good if you ask me :P
Edited by Inline 6
 Share
    • A year of slogging through this bearing issue and finally fixed. What a nightmare. The oil pressure increase did not fix the problem. If you would like to read all the details in case you ever run into a similar issue visit my thread on Yellow Bullet. https://www.yellowbullet.com/threads/continuous-rod-bearing-issues.2689569/?post_id=74193031&nested_view=1&sortby=oldest#post-74193031 In the end the rod bearings themselves were the issue. I had switched from ACL (first engine) to King because that was all we could get at the time and I thought nothing of it. Put the ACL's back in after a year of taking the pan off multiple times to change many things. Issue resolved. Can't believe it was just the bearings themselves all along. It has now been about two years since I drove the car on the street or had it at the track. At some point I had installed all solid and spherical bushings in the rear but had never aligned it since it just went on and off the dyno. Alignment was the first thing to do. (Old photo but same concept) Then I took the transmission out and went through it. This was my first gearset install and I've done about 15 since this one and learned a lot and wanted to apply some of these tweaks to mine. The aftermarket shift forks take very well to some modification and I wanted to make that change. Shifts are now super smooth and no having to find the gear. I also recut the 5th and reverse shift sleeves - always wanted to try this and see how well it works. It works very well! No grinds or having to do a second attempt going into reverse and 5th is perfect. Before During After Going back in In rummaging through my spare trans parts box I found the only parts I've ever broke on a stock trans; the 3-4 shift fork - twice!
    • It also depends on gearbox ratio. Those drag cars running 7s passes aren't doing it on an overdrive gear ratio (probably). 1:1 is "fine", the critical RPM for a 50' single driveshaft in chromemoly is 6900rpm.... ....but when you shift into 5th and use 0:73 or 0:8 it all changes. Do you know their rear diff ratio? etc. That's the stuff that matters with regards to it. Whether it actually matters given your use application is also relevent. You may never get into those scenarios, like most ruined GTR's from Western Sydney don't :p
    • but for how long? would it handle a few laps around SMSP in anger?
    • And over it. Need to stop it coming through the floor.
    • Is it running the standard ECU? some sort of data log might help understand where timing, AFRs etc are at.  If it is standard ECU something like Nissan Datascan would help
