The Sa Wasteland
Cubes
 Share
i think they banned you for the blue mesh and the wheels. the rick roll just gave them a legit reason to do it.
You think? ;) You're prob 100% spot on there :D
Oh no, I upset them :dry: I'm devastated :P
Edited by RubyRS4
im sure theyll be mourning the loss of a valued forum member and contributor for seconds to come.
when theyre not throwing insults at your banned self.
Edited by scandyflick
Yeah, I'm almost certain they're having unlimited and unrestricted flaming sessions.
Time for the elite keyboard warriors to join in!
"Quick, he can't respond, let's say something nasty!" :dry:
The score is now: 7 forums I've been banned from; 2 of them permanent IP bans :D
Edited by RubyRS4
did you get ip'd on ns? ill actually lol if you did.
Dunno. I couldn't give a shit enough to try anyways :D
Guess NS members don't like it being pointed out how stupid they are. ;)
Well, I'm off for my lunch break ... I'm going for a cry at the tragic loss :P I'll try to compose myself and HTFU before I return. :dry:
Edited by RubyRS4
:D This is great, Might invite the NS guys over here for some fun, Think they'd have a ball over here!!
So the guy that is spearheading the SAU SA has been banned from 7 forums......Geeez you guys know how to pick em.... :dry:
Just looking through ebay and found this, VP commodore styles much!
*looks a rear wheel arches* .... *Runs to vomit*
An R33 AND those wheel arches, no wonder you had to vomit.
Hey mate..
Editted by SLED
9:1 afaik.
just for comparison, my old toyota ran a cr of 10.5:1 and didnt have any problems on any premium fuel. cant see how the lower compression nissan engine would suffer problems.
Compression ratios and cylinder pressures are not synonymous.
You can have 2 identical engines with identical comp ratios, identical ignition timing, identical cylinder and valve seat wear, identical fuel RON and yet have totally different cylinder pressures.
Alter the valve overlap (valve timing) either by adj cam gears or lobe profiles and cylinder pressures start to alter considerably.
Drag racers dial compression in or out of their engines using this method as one of many.
 Share
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
    • Id like to race in the US i think alot of those track would suit me   For the s15? Youd be stuck between club sprint and the new Open Am wouldnt you depending on how much interior you have left in
