i think they banned you for the blue mesh and the wheels. the rick roll just gave them a legit reason to do it.
You think? ;) You're prob 100% spot on there :D
Oh no, I upset them :dry: I'm devastated :P
Edited by RubyRS4
im sure theyll be mourning the loss of a valued forum member and contributor for seconds to come.
when theyre not throwing insults at your banned self.
Edited by scandyflick
Yeah, I'm almost certain they're having unlimited and unrestricted flaming sessions.
Time for the elite keyboard warriors to join in!
"Quick, he can't respond, let's say something nasty!" :dry:
The score is now: 7 forums I've been banned from; 2 of them permanent IP bans :D
Edited by RubyRS4
did you get ip'd on ns? ill actually lol if you did.
Dunno. I couldn't give a shit enough to try anyways :D
Guess NS members don't like it being pointed out how stupid they are. ;)
Well, I'm off for my lunch break ... I'm going for a cry at the tragic loss :P I'll try to compose myself and HTFU before I return. :dry:
Edited by RubyRS4
:D This is great, Might invite the NS guys over here for some fun, Think they'd have a ball over here!!
So the guy that is spearheading the SAU SA has been banned from 7 forums......Geeez you guys know how to pick em.... :dry:
Hey mate..
Editted by SLED
9:1 afaik.
just for comparison, my old toyota ran a cr of 10.5:1 and didnt have any problems on any premium fuel. cant see how the lower compression nissan engine would suffer problems.
Compression ratios and cylinder pressures are not synonymous.
You can have 2 identical engines with identical comp ratios, identical ignition timing, identical cylinder and valve seat wear, identical fuel RON and yet have totally different cylinder pressures.
Alter the valve overlap (valve timing) either by adj cam gears or lobe profiles and cylinder pressures start to alter considerably.
Drag racers dial compression in or out of their engines using this method as one of many.
    • This piece is obscenely discontinued. I honestly hate the frameless window design because the rubber gets stressed and the guides as well every time you open and close the door.
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
