anyone know where to get that uber cool coloured mesh from? ive tried profix and midas, but they say its only show car material; needs to be exclusively ordered from hyundai..?
Edited by steveP
Hey - why is there so much beef between SAU and NS anyway?
I heard it was because most of you think that NS gets bad rep with the cops, but it was SAU that tried to befriend cops and then got defected, right? Yet us ns.com peeps don't have that problem at all... so that must not be the problem.
so...what is the problem ?
I'm gonna step in here and try and nip things in the bud cause I can see this getting out of hand.
Be warned that not only will your posts get deleted immediately but you face a possible life time ban from SAU if everyone from ns.com comes on here for some retribution towards Ruby or other members.
Ruby, SteveP, 5LTBETR & Deluxe, consider this a friendly early warning.
EDIT: SteveP, the couple of times I've seen you out, you're as quiet as a mouse, but so heroic in here.
I dont think its so much of a beef, its like two brothers living in the same room, or SA and VIC.
I dont have an issue with NS, having previously been a member when i owned my S13, maybe someone with the hate inside their soul can shed some light?
I also wonder this. Everytime I visit the SA section here I always read atleast one or 2 stabs at NS, yet when I read NS (alot more then SAU) I rarely even see a mention of SAU. :dry:
hrmm oh well back to classic skylines.
Yeh i dont understand either Bill, it all happened between a few people in the All Japen Day thread over on the corner of NS.com, and then today it has happened again, but seems to be with the same SAU member.
I used to frequent here alot more before, but things have changed, and now see myself at NS more than here now, I used to be a "Yeh NS is so childish" sorta person, but wow how things can turn!!
Thanks Pete for the early warning!!
i think they banned you for the blue mesh and the wheels. the rick roll just gave them a legit reason to do it.
... just sayin.
correct
Hello :D
Just wanted to say that I have not bagged RUBY at all... yet.
Just also would like to add that he asks for it with his behavior.
I would just like to say that I did
and will continue to do so
The score is now: 7 forums I've been banned from; 2 of them permanent IP bans :dry:
how many e-creds does that take your tally to now?
how many more before you win the giant panda bear?
Well the issue is resolved. Found some octane booster in my shed, put it in this morning and she runs fine now. f**king shit fuel. :dry:
Edit: I should add, it doesn't matter if the engine is forced or na, shit fuel is still shit fuel. Don't you think NA cars suffer detonation too?
I've got a new name for V Power: Vagina Power = its a c*nt of a fuel :D
Just looking through ebay and found this, VP commodore styles much!
*looks a rear wheel arches* .... *Runs to vomit*
:P:sick:
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
