does anyone have a power fc HAND CONTROLLER that could suit of a 32/33 gtr power fc computer that i could just test on mine?
need to find out if the djetro versions work with my computer as im not sure if mine computer is a djetro. itll only take a few minutes :D
Front part of the exhaust will need changing too. Buy a GTT, much much simpler when considering registration hassles too....
umm not really.. same make of car, release with different engine, all you should have to do is break upgrade and its 100% legal!!!
I'm not free till 3:00-3:30 due to work after which I'm going to Super Cup but I'll make sure if you need it that it's available for you
thats all good dude, im in no rush just wanted to know which HC is going to work on mine so i dont buy the wrong one :D
give me a msg or call whenever you free. ill be at drifts on sunday though :(
ok, so wtf happened with the cruise up at windy point tonight?
i rocked up, didn't even get to see anything. just got out of car, cops arrived... went for a quick walk, 5 min later empty car park and a cop car leaving the scene???
where the hell did everyone move on to? think i spotted typevu's car in the carpark but not 100% sure, only had time to park and that's it.
was the cruise any good? :(
I dont know what happened either. I was coming in a bit later, so I called someone I know and he said they are heading to Lofty (from Clarendon or something... I dunno), well a handful of cars rocked up and thats about it. Were a few different groups around, dont know if they were reminants of the cruise...
Turned out to be a good night, did some camera work.
I don't know the in and outs of it all but regardless it's a waste of time anyhow!!!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
