So i can get Krispy Kremes at the moment, original glaze, for $18 per box, one dozen in a box.
Was gonna make a new thread, but i dont wanna feel andrews banstick ill just pop it in here.
Money can be given as cash or EFT to me and ill withdraw. Pickup of the donuts can occur at my workplace in the city after 20th June, and money is due in by the 11th June.
Please note, i will not be delivering any donuts to anyone, so if you can't pick them up from me, don't order.
PM me with how many boxes you would like, name and address, and how you wish to transfer the cashola to me.
If you need to refer back to this post, the link is in my sig, or here http://www.skylinesaustralia.com/forums/Sa...;gopid=4614789#
Krispy_Kreme_Poster.doc
im just that fast, the black keeps peeling off
alternatively you could start baking for us all penny :) hint hint
Haha im not sure you would want that....
I tried making mini cupcakes, they turned out like fudge. I also stuffed up the icing so I used nutella....
Told everyone at work they were fudge cakes, everyone loved them... little did they know how much of a fail my cupcakes really were.
fudged up cakes, sounds like my cooking experiences.
burnt every meal in yr 12 cooking, only thing i got a good mark on was absolutely raw in the middle they just couldnt see that.
btw someone buy this, f ing gangsta
http://www.carsales.com.au/all-cars/privat...id=121635EDE2B2
Edited by Inline 6
Lucius Washington: You're not gonna live forever.
Ricky Bobby: No one lives forever, no one. But with advances in modern science and my high level income, it's not crazy to think I can live to be 245, maybe 300. Heck, I just read in the newspaper that they put a pig heart in some guy from Russia. Do you know what that means?
Lucius Washington: No, I don't know what that means. I guess longer life.
Ricky Bobby: No, he didn't live. It's just exciting that we're trying things like that.
u do know im not a tax accountant right :) i work for submarine corp. might know a lil more than your average joe on the subject however
busy time is june month end on wards for financial year reporting. coming soon..panick
and are you scared im impeding on your post whor crown?
Edited by Inline 6
i have new wheels. flush fitment wins. now someone buy my enkeis so im not broke as a joke.
lol @ scandy, did that really call for an sms? :D
lol, what a tight arse. admittedly that pic sucked, watch this space though.
oh yeah andrew, wanna buy my enkeis? :D
    • These are small points I should actually add to my original post. GKtech makes an extended slave line for this conversion. It's what I use, and it works well. You'll also need a CD009 slave cylinder.  S/R Chassis Z33/Z34 Conversion braided clutch line As for transmission sensors, you'll need to both extend the wiring and replace the connectors. I can't recall which is which, but one is your neutral switch and the other the reverse switch. As they are just switches, just test for continuity with your transmission in neutral or reverse to figure out which is which. Connectors:  VQ35 neutral Switch Connector | Wiring Specialties VQ35 Reverse Switch Connector | Wiring Specialties
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
    • What are your thoughts on this after having it for a while, worth getting?
    • Downshifts are harder on transmissions than upshifts, the input shaft naturally slows down once disconnected from the engine so the synchros aren't doing all the work. There's no "natural" tendency for an input shaft to increase RPM. Something is not right there, I don't have a great answer on what. You can try a dedicated GL4 75W90, I plan to switch to Motorcraft XT-M5-QS which is supposedly a very good 75W90 for NB Miatas which have a weirdly sensitive transmission from the factory. I would chase down why your clutch is making a hissing noise, that's not normal. It might be no big deal but in the absence of anything else to investigate I would look at that.
