Injectors won't help the turbo make power but cams will.
Also Garrett prices were increased 30% at the end of last year.
My turbo i got 18 months ago for 1000+ GST trade i can't get for less than $1490 now. It'll be interesting to see of HKS have also mover their prices because Garrett will have moved their prices in to HKS range if they haven't
I know Phu talked a lot of smack too :P
But he may have had a massive turbo .... great if you own a dyno queen, but forget mega lag for the street.
I remember MattR's white ex-JMS R32GTR that made over 500rwkw, but with the T51R made very little power until around 4,500rpm - when it would make 100rwkw per 1,000rm and the power hit like a hammer. Was quite insane. Awesome for the drag strip and dynos, bloody horrible for the street.
Hence why Munro has gotten rid of his and downgraded to a pair of 25/40s for his RB30DETT streeter - significantly improved streetability for a relatively small sacrifice in power. Puts a MASSIVE smile on your face too :):P :P
Turbo back exhaust, pod filter, intercooler, 12psi boost, fuel pump and remapped ECU(can get it done through turbo tune[my mate got his done there with the mods I mentioned and got a smidge under 200rwkw on their dyno])
i got 186kw when willal got there mainline dyno and i had 3" turbo back exhaust, fmic, power fc, fuel pump and boost was 13.8 psi so go figure! same as my mechanics r34 gtt he got 191kw!
^^^ The RB25DET NEO is a vastly superior motor to the R33 RBD25ET including enhanced valve timing, cam timimng and various other tweaks. I am surprised your results were so close Son - often there is 10-20% difference between NEO and non-NEO motors with the same mods.
my car was breathing better than his with the decat, straight through exhaust. but it seems right normally there's a difference of 5-20kw between neo and non neo rb25! but the difference was powerband, mine boosts quicker than his but ran out of puff at the higher rev range while his car ate mine at that point, it felt alot more punchy at top end
but i think the extra bit of torque and power comes from more duration and lift from the cams! i'm not sure how vvt works but i think the cams twist? like how v tech kicks in! i could be wrong but that's my guess
ok cool
ill have a look at some garrett turbos tomoro if i get time....see what the deal is with them :)
thanks heaps guys :P
Im running standard turbo at 12psi, making a little over 200rwkw with power fc, fmic, free flowing exhaust, bleed valve. standard fuel pump, coilpacks, injectors, cams + gears, etc. i've considered the turbo upgrade options, but have something else in mind at the moment. high flow turbo will see 250ish, maybe a bit less, but if your building a dyno queen, your gonna need something like Ryan has on his 33, i think its 3582R? or if its a dyno queen, read: not for road use, you will probably benefit from a high mount turbo setup.
anyone really listened to Lily Allen's new song lyrics?
Oh he treats me with respect
He says he loves me all the time
He calls me 15 times a day
He likes to make sure that I'm fine
You know I've never met a man
who's made me feel quite so secure
He's not like all them other boys
They're all so dumb and immature
There's just one thing
that's getting in the way
When we go up to bed
you're just no good
Its such a shame
I look into your eyes
I want to get to know you
And then you make this noise
and its apparent it's all over
It's not fair
And I think you're really mean
Oh you're supposed to care
But you never make me scream
You never make me scream
Oh it's not fair
And it's really not ok
It's really not ok
It's really not ok
But all you do is take
Yeah all you do is take
Oh I lie here
in the wet patch
In the middle of the bed
I'm feeling pretty
damn hard done by
I spent ages giving head
Then I remember
all the nice things
that you ever said to me
Maybe I'm just overreacting
maybe you're the one for me
you're just no good
It's such a shame
and it's apparent it's all over
It's not fair
Oh it's not fair
It's really not ok
It's really not ok
you're just no good
It's such a shame
It's not fair
Oh it's not fair
It's really not ok
It's really not ok
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
