:) I love how you keep everyone updated on your life story.
:bunny: Selling a house is hardly a life story. Sorry, I thought this was Wasteland :rofl:
But seeing as you asked .....
Life Story entry #315 - Stagea has gearbox problems. Stuck in third gear.
Life Story entry #316 - Agent informs me I have offer of $xxx,xxx on house. Offer accepted.
Life Story entry #317 - Shopping for next toy. Have 30 days to seek new ride.
:blink:
Edited by RubyRS4
Damn ...
Stagea is stuck in 3rd gear. A/T light flashes at me and stag drives in 3rd gear (since lunchtime today).
LOL, not you too!
The company Ford cranked over very slow (almost like a dead battery) before firing up this morning then put the tranny into limp mode.
Drove very slowly to the nearby Ford dealer and paid the guy $62 just to tell me that there were no codes logged in the ECU.
If I had just turned it off and restarted it again it would've cleared the ECU (that's all he did) but was worried the battery was on its way out and wouldn't restart. :bunny:
I'm about to do an oil change and the best I've come up with is:
http://ontherunmotorsports.com/catalog/index.php?cPath=23
and locally:
http://www.emtechautomotive.com.au/index.p...070f2abaf9008a4
So yeah.... I'm interested in getting my hands on motor oil and gearbox/diff oil
LOL, not you too!
If I had just turned it off and restarted it again it would've cleared the ECU (that's all he did) but was worried the battery was on its way out and wouldn't restart. :rofl:
Bloody inconvenient isn't it? :bunny:
Gotta drive the silver stagea tomorrow anyways. So the black stag gets the week off anyway.
Well autobarn quoted me $996 for a 20L drum of gear 300, and thats basically retail price. Ive emailed some companies interstate so once i hear back from them I'll let you guys know. If i can get a 60L drum, you guys can just pay me for how much you need.
Have you asked anyone about 300V Chrono?
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
