do it. only have 3 spaces left.
those little bread dinner rolls u buy from the supermarket frozen
chuck those buggers in the oven n toast em and chuck in some shaved chicken and jarlsberg
pimpin.
rick james never had it as good as me - this post is 4 ruby haha
-D
may need one on the way home if my gearbox goes bang.
Your gearbox wont go bang, my gearbox crunched 3rd from the day i brought it. I worked out i just needed to shift slower. 4 years later and its still working fine :P
^^you mean from 1st to 2nd? it's normal when cold... i think double clutching is a way to get around it
Yeah from 1st to 2nd, especially at higher revs. but also going into 1st like at traffic lights etc. But it seems to have stopped crunching/grinding all together now so Im happy with that :P
Dropped the mrs of at work this morning and for some reason the car felt like it had heaps more poke than normal.... I don't know if it's just me but the car seems to behave differently (response wise) on different days lately....hmm!
Well Im off to buy some oil and a filter today for the 32. Searched SAU on what oil would be good for a RB20DET, that just confused me more lol. The car has 158k on it but its been extremely well looked after. As far as I can tell, Motul Turbolight 4100 would be good for it.
If anyone has any suggestions, that would be greatly appreciated, otherwise I'll just get that.
I spoke with some lads some time ago about the Motul oils. The 4100 is good for 10,000kms but who's going to leave the same oil in their car for 10,000kms? 8100 is half the price and is changed twice as often (every 5,000kms). The end result was: with the 8100 the two oil changes every 10,000kms (5.000kms each) mean you'll have fresher oil more often.
So I stick with the 8100 every 5,000kms. Same cost in the end.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
