Just got back from a little city and Eagle on the Hill cruise with Munro in the 35. Damn that car is fast (and hot). Stopped at the BP Hampstead Rd on the way home and you shoulda seen the crowd that gathered around it :(
Just got back from a little city and Eagle on the Hill cruise with Munro in the 35. Damn that car is fast (and hot). Stopped at the BP Hampstead Rd on the way home and you shoulda seen the crowd that gathered around it :)
i reckon i may have saw you. to the spotted thread :(
and scandy my bros should arrive in aus in the next couple of weeks again i wont be test driving, after a brief phone call she understands the words hello :) gonna be an interesting convo going on when she gets here.
Edited by Inline 6
Well, the results are in if anyone cares... Had a boost controller issue, only able to wind 16psi into it but still good numbers!
Pretty good number there :( What other mods did you end up doing? or are you just running the same setup as me?
I'd be interested to see what it makes on a mainline.
Soooo wouldnt mind this:
A mate of mine has one. With a few mods too. They're definitely not a shy car. :P
I wouldn't say no to one in my garage.
Another mate has recently bought himself a 370Z with a few mods. I'll be going for a spin in it shortly when it arrives :P
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue.
    • Anything above ~9.5V is acceptable. The higher the better, but it will almost always drop to at least 10.5V, if not lower, even with a new big battery and everything else being good. 9.76 is not a concern. If it goes below 9, you'd be sure that there's a problem with either the battery or the connections.
    • It's new almost. Under a year old i think and I've tested it twice at supercheap
    • Glue the head from a Pez dispenser on it. Goofy, or Winnie the Pooh, so something.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
