just got quoted $99 for captain thread to come out to me (salisbury north) and remove the snapped coilpack bolt, jesus h. christ. Anyone know of an alternative service?
ill be interested to know too Damo, i've got the same issue.
was using my GMC cordless drill to bolt my coils back in, battery went flat so i borrowed my dads DeWalt cordless, went to fasten the next bolt, and SNAP. (i did set the drill to fastening setting, not drilling) Pretty tough tools those dewalts!
coil does work fine with one bolt fastened though, so not too worried about it for now, but i do want it fixed down the track
Grab a set of ezy-outs and hope to hell you dont snap one in there. Or head to GRH supplies at wingfield, ask for Laurie and tell him your problem. Tell him i sent you and he'll look after you on pricing.
obviously these still need to be watermarked.
normal copyright shit blah blah blah. ©
and for the f**k of it, this is parked next door.
Edited by scandyflick
Is it true the phrase 'heaps good' is a SA thing only ?
are you referring to the fact that "SA Great" has actually been replaced with "SA Heaps Good"??? coz yeah, that advertising campain is an SA only thing... but i dont think we were the first people and still the only people in the world to use 'heaps good; in a sencance =)
watched fast and furious 4 last night............well.......it was ok. too much CGI for my liking and i got lost about half way thru cause i just had nfi what the hell was going on!!! lol
Ever seen the movie (also with Vin Diesel) "A Man Apart"? Just add that with the first FnF and there you have it.
Here's some pub ammo for you:
Vin Diesel's real name is Mark Vincent
Vin Diesel also has a twin
i live with a pair of RETARDS!!!!!!!!!!!!
leaving the heater on foll bore overnight to dry your clothes on a clothes rack less than a metre away from the outlet so that your clothes are ready for work the next day IS NOT A GOOD IDEA.
my throat hurts from yelling at the w4nkers.
"its ok i left my door open so that if i smelt smoke i could get up and sort it"
FFS
the most unbelievable thing is i live a block and a 1/2 from a fkn laundromat!!!!!
RAWR
love ya pic james bring it to the dyno day :D should be a match for my pulsar
Think even your pulsar would kill the Honda! Atmo 1.2ltr, 63 hp, 10.2:1 compression, 5 spd and weighing only 700kg! But it does leave the missus's festiva for dead, not that that is much to brag about :P
Edited by Jamesrb25
Vin Diesel also cannot act for shit
i heard he faked it with you and you bought it :P
and james the time to beat is 0-100km in 18sec ofcourse never do such things on the street thats just dangerous. take your ride out to mallala and give it a try :spam:
i reckon the gtr would hit 200 quicker :D
Edited by Inline 6
and james the time to beat is 0-100km in 18sec ofcourse never do such things on the street thats just dangerous. take your ride out to mallala and give it a try :D
Nice strong tail wind coupled with aerodynamics of a house brick, i may just be able to match that 18 seconds :spam:
i think its cause they searching for some technical character development plot twisting rollercoaster when its just, she got killed he went n killed the bad guys. stuff blows up guns get pulled out and a burnout or 2 get laid. o and theres some fine girls in the mix 2
yeah well wtf was Han doing back in the mix? he died :P and then he was alive again............i was like wtf they should have made that movie first then did tokyo drift.......
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
