That is bad timing - just today I bit the bullet and decided I will sell all the R34 gear I had accumulated, but not yet fitted to my 34. Including a set of Super Spark coilpacks with 3 spares.
Dang! oh well, i got JJR ones, 1 year warranty, for $417 delivered. What else you got laying around? Air con facia by any chance? :blink:
Had a blackout last night at work (irrigation piping factory) so from 3am - 6am we did nothing and then when the power came back on - we Just cleaned because by the time the power had retuned the machines had cooled down :blink:
AWESOMEEE!
guess you wont like my plans for the works then.
:P
ps:
colour coded hi-spec lips are gay. i want those foglights, those corner markers, and the clear fronts.
also so very glad i got the s14 skirts instead of the s14a skirts.
Edited by scandyflick
has anyone had to appeal their probationary licence before for no p plates ?
everyone ive spoken to says the court doesnt give a shit that i need my licence for work and that i will cop 6 months disqualification
is this so ? :D
is this so ? :D
depends if its a mandatory loss of licence. nothing u can do when its mandatory (such as the case if you're over 0.05 - automatic 6 months regardless)...
Get a lawyer, they can talk traffic offences down. Give Matthew Mitchell Solicitors a call at 8344 5589 and tell them what you're facing.
-D
i got caught with no p plates.
its a minor frigging thing !
reckon i have a chance of getting off ?
edit// i got done for speeding last october and i learnt my lesson from that , and then i got caught with no p plates in my dads work car.
NO NO NO
i havent appealed before , ive only had my licence just over 12 months.
got done for speeding in october , copped that & now its p plates
ive had a couple of tickets in between now and then but nothing with demerit points attatched (fail to maintain vehicle standards & written warning for disoby stop sign)
Life Story entry #322
Drew from AAA fitted a resonator to the 33 today. Sounds much better. The car is now totally cop-friendly.
While it was up on the hoist, took a peak under the body. The car is clean as. No leaks except for some weeping at the steering rack for the power steering hoses. A quick clean and torquing and I'll check it out again in 5,000kms. Otherwise, no leaks at all, and everything in top condition. All CV boots are top nick.
/waits for keyboard warriors to say oh its your fault you broke the law
Waiting ...
Best bet dude is to get legal advice.
Pretty much depends on the magistrate on the day, and what else prosecution comes up with. If the magistrate can see it as a simply mistake, and he's having a good day, you might be lucky. Go with Dohmars suggestion, get a lawyer or solicitor, grab some character references off past employers or the like and see how you go. Best of luck with it though, it does just sound like a simple mistake though.
Edited by Jamesrb25
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
