They are top flite clubs Steve.....top flite has been owned by calaway for a while now so they are calaway made lol
Nice 1. What shafts are in them?
oh and Dave, prob a good thing I wasn't with you you last night bud.
+1
Matty31 and anyone else that cares - Repco have 20% off nearly everything in store today.
Ok looking at getting a power fc and a new turbo (mines starting to make bearing noise) in the next month or 2. Just wondering if its better to fit both at once or one at a time. I know it means two lots of tunning, but figure i can save myself some cash on the turbo install and do it my self.
James get it done both at the same time.....its cheaper that way i reackon mate
steve that info i dont know.....but it certainly improved my game on the first go at it mate.....so happy with it
I was looking this morning at a Autometer boost gauge at Repco, thing is it doesn't have the mounting cup and they don't stock the cup..... Any mounting ideas other than having to cut a 2 1/16" hole in the dash somewhere (which isn't going to happen!)?
Got a black mounting cup here Steve if you want, $20 it yours
Cheers will keep it in mind, but after having a look around I'm kind of liking the GTR single DIN setup. That way I get rid of the ugly DIN pocket that doesn't quite fit correctly.
Only problem is Defi ($$$$) are the only aftermarket 3 gauge single DIN setups I've come across so far!!!!! Will keep looking....
Fit the Power FC yourself. It's very easy. You wont need a tune as the PFC has a base map already. Unless you have made changes to turbo or injectors. Then save for yuor turbo, injectors and THEN get it tuned.
The FC is second had, had a plug in test on thursday. Not sure of mods it was tuned for though, but at least it started! Was so tempting to say "leave it in there". Slightly high idle on start up, then rough idle, possibly tuned for bigger injectors. Think that my be the way i'll go Ryan :)
Is there a way you can reset then to the base tune?
Anyone watching channel 10 at the moment, they're showing the Isle of Man TT.
That S*#T is crazy, No regard for ones life.
omg i got dizzy watching that front camera view going through those little villages, hills and jumps at 160mph. Couldn't believe it.
yes do an initialization in the settings menu. No hassles what so ever.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
