cheers carl! might look into that. do something productive with my boredom. lol.
its up there on my to-do list. personally, i'd jump at the offer u got
If you can get thru these 17 modules you're in with a chance:
  1. PRSIS301A Determine method of investigation
  2. PRSIS302A Compile investigative report
  3. PRSIS303A Provide quality investigative services to clients
  4. PRSIS304A Conduct surveillance
  5. PRSIS305A Organise and operate surveillance vehicle
  6. PRSIS306A Gather information by factual investigation
  7. PRSIS307A Conduct interviews and take statements
  8. PRSSO302A Maintain a safe workplace and environment
  9. PRSSO306A Maintain effective workplace relationships
  10. PRSSO307A Maintain own work performance and development
  11. PRSSO311A Prepare and present evidence in court
  12. PRSIS308A Operate information gathering equipment
  13. PRSIS309A Perform administrative functions
  14. PRSIS310A Use and maintain operational equipment
  15. PRSSO315A Store and protect information
  16. BSBSBM301A Research business opportunities
  17. PRSIS311A - Work Effectively in the Investigations Industry
It's not as hard as it looks, speak to Kye cause I hooked him up with someone at Adelaide Tafe last year.
By the way Dave......what tickets were you referring to?
in the life of dan......
friggen house company has taken 4.5 months to finally get the paperwork to the builders ready to start building, not impressed. apparently they were also thinking of sending me a added bill for it taking so long when ive only taken 24hrs with each bit of paperwork and nagged them reguarly to get off there ass.
i needed to vent :P
Really?!?!? That sucks. You shouldn't have to pay for there laziness. Does anyone know if the government house incentive is still happening at all, i think i heard it was going to stop.
/snip
looks like fun.
those 90 million dollar ones you wanted me to remind you about. :P
i have another course on my plate at the moment (i probably wont use the diploma, but i have sunk $5k into it and its some good CV filler). I'll be straight onto the certification to be a mini pete after (dont know how that will work cos we r both about the same size).
No probs Carl....I sent you a PM.
EDIT: your reply has just come thru.
I just noticed in the above modules that there was no real mention about Law.
The course will cover that topic to a certain extent but only in the familiarization of the Workers Compensation Act, Privacy Act, etc.
An area you'll cover that you should stay focused on is the gathering of evidence and maintaining a chain of evidence.
Reason I say this is cause too many young cops fall over in court regularly when they get there 1/2 cocked with their evidence and some semi-illiterate lawyer comes along and turns over all their hard work cause they didn't cross all their T's and dot all their I's.
Having said that, court appearances are far and few between these days.
cheers pete, i have a bit of a taste for report writing and building strong cases for my actions from people trying to fleece telstra. a couple of the things i delt with wen accross Sols' desk while he was with us, and lets just say that im glad i did what i did cos some liars would be thousands of $ richer, and i may have ended up jobless
This look pretty interesting Pete, might have to have a chat to you at some stage. Got the info pack from one of Carls links, going to look into it a little further i think! :rofl:
lol, workcover fraudsters need only to look out for slow driving skylines with SLR's on the dash :rofl:
Or bright yellow Honda's, should blend right in with the traffic :D
Edited by Jamesrb25
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
