I can highly recommend jack for solder jockey work ;D (after all Im shit at it and made him do it all)
My dick is still bigger than his tho yall
-D
Bahahaha :laugh:
If any one wants to check out VDO's range of gagues...
http://www.egauges.com/vd2_main.asp
i might be getting Saber gauges depending on the price :laugh:
i recall have a chat to you about saber, i believe i may have included the following words and terms;
cheap
crap
avoid at all costs
also, lol at the post stats for the wasteland.
Damo_R34 2354
Madaz 1914
and a quick question, if i go ahead and say, buy a 2871R, id pretty have to get a retune eh...?
Edited by scandyflick
welcome :laugh:
if your interested in entrering shows and stuff im the SAU:SA Events Coordinator :D
thanks i'll keep it in mind but i think i should spend a bit of time and money on the car first before entering it in shows.
but thats the long term goal anyway, make it showy :D
I would, yes. Fit your EBC, get a retune, profit. If you could get some bigger injectors and a larger AFM while you're at it you'll make better use of the turbo but still, will be sweet regardless
Yep GT2871R will mean injectors 740cc, Z32 AFM, and a remap at the very least (at least the remap will only cost you around $600 including the daughter board) and to get the most out of that turbo you should really get cams. Without cam your looking at around 230rwkw and with cams your looking at 250rwkw. If you don't want that power then look at a GT28RS, that'll be around 220rwkw without cams and 235-240rwkw with cams. Standard SR's will take 250rwkw without a problem depending on how you drive it and how good the tune is.
EDIT!!
I'm pretty sure the use of any harness is illegal in SA.
Edited by D_Stirls
looks like ill just be getting the t28 rebuilt then, ive got other things i need to start getting the money together for. car has to be put on the back burner sooner or later.
cant justify the nigh on $2k.
i was told years ago (by regency) a harness is legal if you have the stock belt still bolted in and functioning.then i got pulled over and fined for not wearing a seatbelt,was using a 4point momo harness...and got the old Rx-7 defected at the same time for my troubles..
who knows really???
