yeh i do a bit, had a blue one with a high mount high flowed t25
the gearboxes are crap especially reverse, and the factory computer is also crap as it is located under the passenger seat which is easily knocked by the passengers feet which in turn pulls out the loom
other that they are a great little FWD car
sounds like the one my mate josh had a while back, not sure what he did with it tho.
think it had guages in the dash?? ..........
TO THE PEOPLE THAT I MESSAGE ABOUT THE STOLLEN LEGNUM
It's been found in Seaton on a blind corner, tourched out.
My mate's going to go have a look at it tomorrow afternoon but there's a P.I. wanting a interview with him about it all. Should be fine considering he did nothing wrong and it's most likely routine for insurence reasons.
Stupid faggots who steal shit because they are too shit to get their own job and earn things like everyone else should be shipped over to some shithole country and get rapped!
That's terrible mate, atleast he had insurance, that's one saving grace of the whole thing. You're right though, these bastards should be out their EARNING a living, not stealing their way through one
sorry luke (enr) i thought i sent it to my whole msg book, guess not :)
and nah, its not that chicks car it was my other mate who had the dark green manual one with tiens, vskf's etc. i had it forsale on ns.com but got stollen from the bay around 3ish. left it for 20minutes he said. pics of what it looked like before the fire here. such a nice car :worship:
http://www.nissansilvia.com/forums/index.p...p;#entry5224372
yeah its most likely stripped and tourched but ill find out more and get pics tomorrow.
it had a bodykit and was resprayed blue with pearl through it, the instrument cluster and dash surrounds were sprayed red, had monstar tacho and shift and boost gauge on the a pillar and a black interior
She says a lot of things, she said to me she told you that you were awesome because she didn't want to hurt your feelings, sorry man :D
devo'd. she still owes me a fifty though.
what, are you telling me you havent pop rivited sheets of metal to the side of your car?? i call lies!!
fibreglass my fishy friend.
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
    • Plug and play. Need a tune. It's a PowerFC, same as any other PFC, just not needing an AFM.
