I'm not gay, the guy who feels me is
and guys that wear man scarves.
did glenda end up getting the rotor? if he didnt i know of an s4/5 with a fair bit of awesome shit going for 10k.
Nope, but the XR4 has left, finally! He's now buying Josh's Silvia, and Josh is buying a 33 by the looks of it, or a DC2 Integra
never fear Josh is here
dave & luke, running with the 33 idea at the moment......cant find shit for a reasonable price except for the blue one, this is the kind of car/look i want (minus the auto)
http://www.carsales.com.au/all-cars/privat...me&__Nne=15
last night a white 31 was into a pole at the start of the express way, looks like they tried to take the entry to the express way too quickly in the wet and went head first into one of the light poles.
Hope it was no one from on here!!!
The boxes aren't THAT expensive, it's the parts you'll need while doing the conversion. Give smooth a buzz and see what they'll charge so you've got a ballpark figure before you even bother. Boy Glenn will love this, a 33 AND auto :)
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
    • Plug and play. Need a tune. It's a PowerFC, same as any other PFC, just not needing an AFM.
    • Genuine GTR seat? There are none you would actually want for <$3k a pair.
