Thats cool Dave lol,
just thought I'd throw it out there anyway incase you dont check the fs section often Like I do... twice a day sometimes LOL.
I want cheap coilovers SOMEONE HELP :mellow:
I got a set of 4 Tanabe Suster Damper (not coilovers though) sitting in my garage you can have for $50 - only done like 25k. lol.
im not 100% that hes still going, but just use $10 from my deposit and ill wire over another $20 now, if he doesnt come just put it all towards my payment
Yep not a problem damo....as it stands dont worry about wiring another $20 through....i will just use the $10 out of yours mate
:mellow: Under $1000?
wont get anything worth using for under $1k.
brand spanking HSD's youre looking at $1200 and up i reckon. set of 2nd hand good condition jap coilovers will set you back $1500 on, brand news JIC's start at $1950.
my cusco's set me back $1500 when the dollar was rubbish. 2nd hand, but in awesome condish.
oh, and no more speed camera signs, pollies are saying its pointing out where they are, which is dangerous to them blah blah
http://www.news.com.au/story/0,27574,25789585-421,00.html
read that. lol'd. i doubt that many speed camera operators get harassed/threatened/bashed. like to see em work my job a couple saturday nights. they might go crazy with the number of threats they get.
Edited by scandyflick
Oh cheers for the heads up Dave... I'll just wait till I save a bit more kesh.
Thanks for the offer Dion but its already got Tein struts in it. Only problem is the height lol sits a bit heigh for my liking but the handleing isn't too shabby
The search continues
yeah, need to be tuckin mad tyre. make sure you get base height coilovers. can sit it on the deck and still have relatively comfortable suspension.
or just buy american gangster style airbag suspension. :mellow:
lol pretty sure this suspension will have it dumped, the suspension is for a GTR but I had the fronts in my GTST
Also Scandy, so Hypergear do rebuilds aswell? because I cant see anything mentioned on their site, only new stuff.
yup.
hypergear on ns.
We can also high flow your old or blown T2x or T3x turbochargers from $800, Or rebuild from $400.
and from a pm;
To replace with a GT2860RS CHRA you will be looking at $1300AUD. Same spec in sleeve bearing is $800. Or rebuild assume your original wheels and shaft are good is $400.
Just had a customer cancel a booking for tomorrow because his car got defected, don't suppose the government is going to take into account the effect these stupid new laws will have on small business!
One of the things he got defected for... rear suspension 5MM to low....yes thats right FIVE millimetres...
5mm... you for cereal?
Is that 5mm lower than stock ... or 5mm lower than the lowest legal height?
I keep my suspension 10-15mm above the lowest legal height ... just to be sure. :mellow:
Edited by RubyRS4
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
    • Plug and play. Need a tune. It's a PowerFC, same as any other PFC, just not needing an AFM.
