anyone have some decent res pictures of skylines from car shows or private photo shoots that they dont mind me using for promotional material? Can you link to me your photo hosting site or email them to me?
Can anyone give me some advice? I have a Haltech E11v2 that i will be installing in my car soon, should i use the 3 bar map sensor that came with it, or go buy a z32 afm? I am aiming for 250rwkw+. Which one would be better for a stable tune, less likely to play up, and doesn't need to keep getting re-tuned.
From what I understand...
A Map sensor will need to be retuned everytime you do something different to the car from what I understand but wont stuff up,
Where as a afm will sort of 'adapt' to minor mods but can stuff up.
haltech ecu's are pretty damn hardcore. they shit over powerfc's, unfortunately theyre usually 3 times the price most of the time
map sensor wont be as affected by resin coming off a reusable air filter. my maf sensors have cooked a couple times after getting the medium cleaned after getting some of the oil on the sensor and then the sensor heats up and stops reporting the right flow. they can be cleaned, but i'd be going for the map sensor (I think thats what the powerfc D-jetro's are too, someone correct me if Im wrong)
-D
Damo/Allllllll of SAU, longtime no talk :D .
I have a crapload of high res skyline pics from various shows and many of jacks 33, and just heaps of skyline photos in general. What sort of pics are ya after? :D
Bosch 044 flow's 30% more then GTR iirc?
probably a better option depending on what power you want
true but a nismo fuel pump which flows just as well as the 044 can be mounted in the stock cradle without mods
the 044 is around $280 or so and the nismo is $450 odd, but if you're like me and have to pay for labour then its almost worth springing for the nismo
the 044 is an external fuel pump, im not sure how well they go with being submerged but i know people have done it
the 040 is internal but doesnt flow anywhere as near as much - its a good replacement for the oem pump but if ur running heaps of boost or aftermarket injectors you'd probably be best off just getting nismo - i plan to get nismo when it comes time to replace it. so far my stocker is still going nice
-D
-D
Ive got a GTR fuel pump in my car which was flowing 223rwkw but was leaning out which i think was due to injectors restricting flow but the stock GTR pump is fairly good :D
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
