but wait here is more to it
Q: so, more habibs is actually desirable?
A: If you want to move fast or have more power, I think it's obvious why more habibs would make this happen.
ECU needs to know how many habibs (air) are coming in da club so that it can get the spark plugs (chicks) and fuel (had in the shape of a gun) and then???
CHK CHK BOOM!!!
Good find Krishy. I laughed so hard. :D
anyone know of a plastic welder in sa?
There is Morrells on South Road, Richmond. Its a small paint shop behind the Morrells car yard. He's done my plastics for my bikes and is doing the bodykit for my 33.
lollollol
oh, and masive congrats to Graham Manou who is making his test debut
heck yes! Quality player, when i played at the Jets i trained with him a fair bit. Also trained with Shannon Hurn, before he went to AFL, Mark Cosgrove and Chris Duval (before he went to Tassie).
u do realise that a NA engine has more torque due to the fact it dosent have forced induction to get everything going?
you do realise that you are wrong?
seriously, whatever you are smoking, i think you need to stop. but hey, if you want to call the good people at nissan (and in fact every other company that has made turbo versions and NA versions of the same motor) liars for publishing power figures that prove otherwise, you go for it.
fmylife.com
Today, I tried to be sexy and put a condom on with my mouth. Instead, I inhaled it and my boyfriend broke three of my ribs giving me the Heimlich maneuver. FML
Today, my boyfriend and I made a date to try to save our relationship. I sat in his room for hours while he watched YouTube videos of World of Warcraft. FML
Today, I told my therapist that I suspected my partner was unfaithful, but I don't think he believed me. "What, did you find a membership card to a sex club in his wallet or something?" he asked. When I got home, I looked in my partner's wallet. I found a membership card to a sex club. FML
Today, I was downtown with my boyfriend around Noon when we walked past a few guys who shouted out to me "You're the most beautiful girl we've seen all day". My boyfriend's response was "It's still early." FML
Today, my two year old daughter did not want to leave the toy store, when I picked her up she started screaming at the top of her lungs, "YOU'RE NOT MY DADDY!". FML
Today, I cleaned my house after a big party. Everything was great when my parents came home. Except for the bottle of hot and spicy mustard next to the shampoo in the shower. No one knows how it got there. I'm busted because of mustard. FML
Not sure where the RB25DET engine torque figure listed above came from, but it's actually quoted by Nissan as 30.0kgm at 4800rpm - just under 295Nm.
The UK skyline forum and another source..... Nissan
seat of the pants you can feel a huge difference in mid range from S1 R34 and S2 models in the same state of tune , even more so when you add a 270.00 part it improves the car dramatically in the low to mid range punch to make it soooo much better to drive daily
next improvement
dumping the heavy flywheel/shitty clutch on mine in a few weeks to free up the rpm Revs more, but the torque feel will go away when I do that.. oh well worth it
if you crazy kids have a spare few minutes, have a read of these comedy gold threads:
http://www.skylinesaustralia.com/forums/Im...-I-t278236.html
http://www.skylinesaustralia.com/forums/Ca...er-t278152.html
what an idiot......needs a good kick to the nads to sort him out..lol
In super saddening news, the intermittent transmission fault that has delayed me taking delivery of my new car has returned (despite new vehicle speed sensors being replaced and a full trans service including $1,200 of CVT fluid), so I won't be gong to Melbourne to pick it up tomorrow :);) ;) Hopefully it is a solenoind issue and can be sorted soon, otherise I will have to start looking for another car.
Also spotted James being a champ and dropping off some tyres to me today - thanks mate! Your 33 is clean as!
    • This is a real nostalgia trip for me, I mean SK Bilsteins? I ran those lol Good times.  Good work Duncan, it's not an easy job in many respects. I'm sure the family appreciates it.
    • It's not a dumb question. I was circling this idea myself. User error is always possible!
    • Nope. The seal is in the drive. A new cable would just fill up and continue to convey oil to the speedo head. To check if this is what is happening, take the cluster out, dismantle the speedo and have a look. You probably don't even have to dismantle it. If there is oil coming up the cable, the drive into the speedo will be grossly greasy. I had to manually (and delicately) clean the gunk out of my speedo.
    • Thanks for the quick response mate, and I agree Nismo 555s, Z32 and high flow 2871 in OP6 housing (run by PowerFC) would all be "period correct" and should be a simple, reliable and reasonably quick track car.
    • It is normal for a speedo to read 0-10% high (unfortunately), intended by manufacturers and ADRs (although not in this case) to ensure your speedo does not read low if your tyres are worn. Speaking of which, what size tyres do you have on the rear, and what does they tyre placard say you should have? you can use this https://tiresize.com/calculator/ to determine what % difference that is causing Personally, when I buy tyres for a car I buy a size that will bring the speedo back to being more accurate; it if it reads 5% high I buy tyres that are 5% larger diameter. If you had an electronic speed sender like R33 onwards, the other option is to add a speedo adjuster but that won't work in R32. Finally, you  might be able to find a different sized gear for the speedo sender but that will be limited to what already exists (and I don't know what sizes do)
