What do you guys think of these rims? My new car may (or may not) be a 350Z, but is black and lowered - so won't look too dissimilar.
I am thinking either these silver/black centres (as in the pic), or straight black centres. But both have a big polished dish like these.
Daniel, I've edited part of your post.
We're going from discussing a specific issue relating to Mitch's car to the way they do their work.
Be warned, if this becomes a slagging match at Turbo Tune for any reason other than the way they handled Mitch's situation (ie. poor workmanship & customer practises) then warnings/bans will be dealt out!
+1
Black car needs some contrast. As they are in the pic is my vote :thumbsup:
Yeah I agree Ruby - I like black centres, but find that with some dish it becomes too dark in there and you lose the shape of the centre and it just looks dirty.
Mind you the attached pic (which is a very similar wheel) doesn't look too bad - but is it much less dish than I am after, so in not an accurate reflection.
Surely even if you had comprehensive insurance it would only cover you if the alarm were armed and they didn't have access to keys. Since I am sure the car wouldn't have been alarmed/locked, and the thieves would surely have had access to your keys - so that argument is completely moot.
I am willing to bet their insurance would have to cover you.
correct.
keys were in the ignition of my car and all the other cars in the shop which even if i did have comp insurance on it , wouldnt do shit...
As in the pic imo
the government said they dont wanna put cash in, they dont f**king need to! the consortium has enough cash! secondly, they said to go through normal planning avenues, and the consortium has! but the government told them they cant have the land they wanted after stalling them for ages
the only way we will get this track is at the polls.
mitch, man that really sux
I will NEVER be going to or recommending anyone to go to turbotune
will pass around the bad word for you. :happy:
I see shaun @ boostwerkx for RB-related needs.
best of luck with it, hassel them every day
then take it to Classic performance in Hackham...See Ash..he's a friggin legend
+1
I've tried telling people on ns.com that years ago when I went there. No one listens as usual.
Pathetic.
Edited by SLED
This email is directed at anyone who has played a part in slowly killing South Australian motor sport, and in turn increased those that tragically lose their lives every year on South Australian roads.
As a voter, I would like to voice my opinion and state that Mike Rann will not be getting my vote unless he wakes up to the demands of so many and provides car enthusiasts with the facility to enjoy their hobbies.... Read More
I am not alone.
A disgruntled voter,
[iNSERT NAME HERE]
please send this too..
[email protected]
and
[email protected]
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
    • Plug and play. Need a tune. It's a PowerFC, same as any other PFC, just not needing an AFM.
