Attn scandy;
How much was your turbo rebuild and hiflo and where did you get it done again? Looking at buying some N1's that are in need of rebuild cheap and sussing my options if its even worth buyin haha
your best (cheapest) bet is to find a pair of blown ceramics and sending them over to Antimatter in melb and get them rebuilt. Hes doing a pair for me at the moment (which i need to get off my arse and pay him the rest of the cash i owe him)
best thing is, if its in the original gtr turbo housing, regency wont know any difference
-D
i was reminded this evening why i rarely drive the s14 to work. people stopping dead in front of me at 80km/h in a merging lane when they have more than ample room to merge, ive had to jump on the skids because i dont have the room to skirt around him, and the guy behind me has had to spear off the side of the road, and the guy in front had the nerve to jump out of his shitbox and abuse me for 'not knowing how to drive.'
f**k i hate shit people.
Attn scandy;
n1's are bb yeah? rebuild kit is $1300 or something for a bb. dunno. could be wrong.
got it done through hypergear (check on ns.com), standard rebuild was $400, highflow was $800.
Edited by scandyflick
got thru it alright, will be ideal with a snorkel later down the track. had a steep old drop off on one side as you go in............got thru it easily, but dont trust my door seals that much to do it more than once
got an irritating as all f**k knock in the front left corner on right hand turns and hard lefts.
rather concerning when youre doing the uh... speed limit through the hills and you hear that.
any suggestions as to what it could be?
^ Hey Scandy.
It could be your wheels hitting the struts? or wheel guard... why that side? maybe it could be due you Adelaide poor camber roads :P
or... you hit the corner hard?
or a leaky strut?
hope that helps....
ps; SwineFlu sucks... a whole week off isnt as good as it seems, you sleep all the time and just plain bored!
Edited by AXTX
no leaky strut, checked that. plenty of wheel-sturt clearance, enough wheel-guard clearance for it to not be that (only scrapes on hard bumps), so im at somewhat of a loss. matty suggested it could be ball joints. seems likely. i reckon theyre oem...
You can buy brand new -5's for less than that.
Coils with camber tops? Not the spherical bearing in the top rattling? I had that with a set of coil's in my car drove me mad till i pulled them out when i sold them and found out what it was...spewing
How much man? I will have a daily soon so I'll just rip my turbos off and send them away if the price is good?
PM me if you dont want it on the forum.
You'll have to PM him for a quote for his labour and parts as Im not sure what the prices are like atm, and if you want to buy a pair of turbos I'll have my stockers for sale after the new ones are fitted, but we're talking a couple months here
-D
turns out the engine i bought off here has a shagged cylinder and bent valves -.-
i am so happy about this
jeez man ur run of bad luck just keeps getting worse
can you fix the cyl with a bigger diameter bore ? could be good excuse for 2.8lt pistons ? ;\
-D
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
