The answer to all your questions there are, no idea :(
I will be pulling it out when i put the new turbo, and ecu in...so 1-2 months time. As for cost, no idea how much they go for, plus i may hang on to it for regency issues. Power wise...Krishy i think is still using a stock series 1 afm, so about 220rwkw, maybe a bit more.
very very nice power figure Dave specially when its untuned.....R33 AFM's are good for about 250rwkw's and that would be most likely maxing them out at that point....i am going to get the car tuned with the stock AFM and see how much we can squeeze out of it before swaping to a Z32....i am only making 211 atm.....Saturday should tell :(
can someone help me out ?
i bought an engine off this forum which was apparently working etc etc and had been pulled apart and put back together professionally but after putting it in the car and
being compression tested it has low compression (waiting on exact figures).
the guy i got it off said that when i picked it up it had a timing belt on it and the timing was set to tdc but ive come to find that it was missing idler and tensioner pulleys , not to mention
it was also missing oil seals around the back of the cam pulleys and its missing bolts off the intake manifold.
it also had heaps of missing coolant lines...
what can i do ?
ask for my money back ?
ask him to pay for repairs ?
shit mitch your situation is getting worse day by day mate.....well you can give the seller the 2 options and see what he says in regards to it....goodluck with it mate....just cant wait to see your ride back on the road
you and me both man !
so over this crap
but i got some good news this morning
got accepted into tafe to study Cert II in Automotive Mechanical , starting jan next year :)
makes me think about my power figures....when i first got my car tuned..it still had its n/a fuel pump and reg...but had a early darkhalf rechipped ecu (before realtime) and rb20 redtop nics injectors...it pulled 175.4kw at the treads..but leaning out big time in the top end....this latest tune it had a bosch 040 pump and a vlt reg...but only pulled 150.....my first tune it was still using the same AFM as when the car was on lpg n/a and had it blown apart a few times.....i dont get it....when it was first tuned....it had the same fuel filter and plugs from over a year previously....me dont know...me too little
Dave, get in touch with luke
he still has his GTR pump, and glenn has a Z32 that he'll no longer need, solves both problems then
Correct, got a nice GTR fuel pump sitting here with your name on it. And Glenda has a Z32, problem solvered
messing around with the valve timing without knowing what you're doing can definitely have an effect on compression.......very easy to dial in and dial out compression by varying the valve timing slightly.
Might be running like crap though but if it's not running yet, be careful of any valve to piston contact
what can i do ?
you can ask for anything but your chances of getting it are minimal since it was a private sale so it's a case of buyer beware. that's why buying engine off wreckers will cost you more because they generally come with a start up warranty, so in this case you would have been covered.
I'm still waiting for you to clear the air about your claims about TT. you read the post that SLED made and yet you didn;t see fit to reply.
SCANDY;
S1 R33 and R32 AFM will support around the 210-220rwkw, but the SII R33 (pink sticker, 3 wire plug) will support around the 235rwkw mark. i wouldn't pay more than $100 with the plug for one. I paid $55+20 for the plug for mine and if you look around you can still find them for that price.
Edited by D_Stirls
how far down south do you live Daniel and how soon do you need it on the road?
Me or Matty could tow it up for you possibly.
if i had a winch on my trailer we'd be right..........but i dont :) and i dont hav my winch on the car yet (or a front towbar point for that fact)
nice. how much? :)
SCANDY;
awesome. cheers dale. ill see what i can find.
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
