that's pretty awesome ruby!
So is my understanding correct about SAU now being cams affiliated:
we join SAU and at such track events we don't have to pay for a day cam licence?
Yiap.
Unfortunately you don't get the 10% cams discount with shannons via a group affiliation - has to be personal. D'oh!
-D
Skylines Australia - South Australia is CAMS affiliated (as of August 2009). This means that SAU:SA members who wish to obtain a CAMS licence for events can now nominate SAU:SA as the CAMS affiliated club on the application form.
Other benefits are listed below:
http://www.cams.com.au/en/Sport/Club%20Zone/New%20Club.aspx
http://www.cams.com.au/About/Insurance.aspx
'This vehicle is ALL MOTOR
Seriously, who needs needs a turbo when
you have a stupidly quick, naturally
aspirated motor? Real motors don't
need forced induction'
This may be true, but in the case of the R34 GT forced induction would be really really helpful.
Unfortunately the Insurance addendum only is valid for Members (and not affiliates). Individual cams licences will get the 10% discount thru shannons, but not thru simply being affiliated with a member club. I called shannons half an hour ago and they confirmed it.
-D
and your comment is as pointless as what you are making it.
Yer always cops at that bp...always get some weird looks when u walk in their driving anything that doesn't look like a holden or ford
With you on that one Shane! That place is always crawling with cops, cant say i've ever had the remarks passed that Dave did though!
Be that as it may, I still wouldnt classify the GT as "Gutless".
Depends how well maintained it has been or how hard of a life its had... and that would determine how long it'll last until something goes BANG - could be a few seconds could be minutes, hours, days, weeks, years, decades, millenias.
the engines coming from JMS so i dont see it being completely f**ked...
its gonna have brand new fluids all through the engine and car (diff,gearbox,brakes etc) and im getting it leak down tested before i buy it.
plus its being fitted professionally.
shouldn't have a problem?
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
