Love the city one "obviously got nothing better to do", who's the sad feck crying about it to the advertiser? lol
Thats what gets me, people who live near the city or the airport that constantly complain about the noise. I bet 80% of these complaints are lodged by old people with nothing else better to do. Bit like the old fart that complained to the council about my dogs barking, four dogs of the same breed in the block!
i got egged last weekend unfortunately had the door open at the time, got the f er's plate n called the cops but they didnt really seem interested.
shoulda just said he was doing burnouts instead they woulda been knocking on his door in no time.
just bought a new oil cooler..
do i fit it with or without oil? how much oild do i put it in if i dont fill it first? CA18DET..
also when im tracking the car and the catch can fills with oil do i put the oil back into the engine or dump it?
cheers
cheers
do it without oil, just fill it to the normal spot on the dipstick, and dump the catch can oil.
I change my oil every track day or dyno day.
belgian beer is by far the best beer ever!! so much awsome drunken times in my life are thanks to belgian beer!
exactly, like rocking up 2 hours late to my birthday when u lived the closest LOL
on another note, EVENING!
Who is going to, or would like to go to, the V8 Supercars at Phillip Island 11th-13th September? :(
It appears I'm going alone ... but would like to share the driving if someone else is trekking over. I might be able to get someone in on a guest pass, as I'm working there.
Anyone? :)
    • Is it a dog or synchro box? I guess either way, if it is new and crunching in one gear only, it has to come out and go back to the shop to check/measure as there is either an assembly or manufacturing issue
    • These are small points I should actually add to my original post. GKtech makes an extended slave line for this conversion. It's what I use, and it works well. You'll also need a CD009 slave cylinder.  S/R Chassis Z33/Z34 Conversion braided clutch line As for transmission sensors, you'll need to both extend the wiring and replace the connectors. I can't recall which is which, but one is your neutral switch and the other the reverse switch. As they are just switches, just test for continuity with your transmission in neutral or reverse to figure out which is which. Connectors:  VQ35 neutral Switch Connector | Wiring Specialties VQ35 Reverse Switch Connector | Wiring Specialties
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
    • What are your thoughts on this after having it for a while, worth getting?
