wasnt that the malpassi one ruby ? Ive had them die a few times on the RB30 and now keep a spare wreckers one in my parts box..lol
Yep. Malpassi. Are they commonly known to die? :P Are they repairable/rebuildable?
Guess I'll be removing it and putting the Nissan one back on.
Edit:
I've done a search and come up with nothing about common problems, except some can split the diaphram. From the sound it is making, I believe the fpr is holding 60psi (should be on 38-40) as fuel is leaking internally into (I assume) a split diaphram. Once full of fuel the noise stops and the pressure drops to about 25psi = one f**ked fpr?
Trying to find out more info. Google is not my friend.
Edited by RubyRS4temp
Its only $40 buy it now Damo.....get it man as your into that sport
Has anyone here installed a Bosch 040 fuel pump into a R33 before? I got so far then got stuck....couldn't actually get the pump and bracket back in the tank. Looking for some help from someone that knows what they are doing.
I have a Bosch 040 currently installed in the car but thinking of upgrading to a GTR fuel pump....
does anyone know how much power can/will a GTR fuel pump support???
the pickup on the GTR one is better then the 040.....on tuesday i was having some issues on the track....had 1/2 tank of fuel and going around the kink on the back straight at mallala the car cut out.....simply no power nothing....and then when the car leveled off it came back to life....same thing happened after the hairpin and coming onto that little straight before the S's.....so blaming it on the fuel pump.....
what else could it be? slightly worried now
if you had half a tank, it aint the pump, unless its mounted too high.
Well thats what i am thinking.....i havnt refueled yet so will be interesting to see how much it takes....i am thinking of switching to a NISMO one that has better pickup......what else could be the issue of the car cutting out twice on the one lap.....on the run the fuel gauge drop dramatically but when i pulled into the pits it was showing that i had 1/2 a tank?????
I know the Stageas have a little 'anti-surge' type sealed craddle the pump sits in. This little craddle is filled with the returning fuel from the fpr. Does the Skyline have something similar? If the pump is suspended low in the tank with no anti-surge device, you may in fact be experiencing fuel starvation ... especially under track conditions/speed.
I dont think the skylines have that ruby....correct me if i am wrong please.....but i do think that what i experienced was in fact fuel starvation....now i am begining to think that a NISMO replacement will be better as its close to what the stock one is.....ie pickup and mounting....also does anyone know what power will a NISMO fuel pump support oh and the price...just really want to get that bit sorted out for the next track day
just make sure the filter is clean.. scott had this problem with his walbro..
was mounted too low and the pump would pick up shit off the bottom and clog the filter.. car would stall and run like shit..
cleaned the filter, moved it up a little and was fixed..
try this?
they are widely used in massive V8's and drag cars cos of the sheer volume of fuel that they can deliver. their website is not particularly helpfull CARTER FUEL DELIVERY i'll try n dig moar up for u
..::edit::..
the smaller ones make great lift pumps. the rotor guys love em
Edit:
which model fuel reg do you have ruby ? they have 3 or 4 models for EFI, some, stock replacement, rising rate, racing hi pressure ???
I would suss you can rebuild the regulator diaphragm and spring rates, but doubt you would need that... the nissan one fails when they get older believe me...lol ,
this is what the regulator looks like inside
you could go this route
Sard fuel regulator
or this one for the 260
Nismo fuel reg
just to throw it out there, carter fuel pumps are tits! they have a massive flow rate:pressure ratio and they are reliable as the sun
hmmmm I would go elsewhere , being from USA where Carter is a cheapo brand , and in my past V8-V10 days I wouldnt go for one
they tended to get bad flow rates on hot days , and would vapour lock easy since the pressure would get too low. a royal pain in the ass
but to each his own
have not seen them vapur lock with the rotory vane ones. but i have only used them on a 186 with a 179 head, and the rolla
http://www.weatherzone.com.au/satellite.js...lye=1&lyf=1
lotsa lighning coming
wow cool I love the lightning,, time to get the camera ready
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
