Abe, place the pump in the exact same position as your stock one. Make sure the bottom of it is inline with the stock one. Looks like u will need to cut the hose alittle shorter and connect that up. Cutting the bottom bracket off is fine as u need to. After that hose clamp it on and slide it into place.
I am slowly getting there with the pump.
I finally stuck my whole arm in there and managed to get the pump into position, that was with out hose clamping it to the cradle. I have now hose clamped it, cut the tail off...just waiting for it to stop raining, while having lunch.
Also, petrol melts the sound deadening in the Tyre well.
mitch, i dont think a 26 head gasket will go on a 25, they have different oil lines
the gaskets will be the same appart from that the 26 will have larger holes where that head studs. The proof is that with 25-26/30 conversions both the 25 and 26 head will fit the 30 block without modifications.
i wasen't quite sure, because the 26 has an oil feed to the head blocked off where as the 25 keeps it (for vvc)... so wasent sure if the head gasket for the 26 still has the hole for the blocked off feed or not hence played it on the safe side. Tho isn't the hole a different shape on the 25, smaller and tear drop shaped? but probably wouldnt matter since the 26 hole would once again be larger...
need the chains coming off the back now so u dont run them over.
thats the next bit im working on, definitely going to need them when i do the fronts thats for sure
lol. plenty of 'otherwise inclined gentlemen' in adelaide. (i got majorly chewed out and refused service from the ex lady for refering to a fag as something rather crude today, lol)
most of them hang at hq on wednesday nights. makes it real easy to throw some moves on the rather large amount of easy ladies that frequent slash dance.
needs more twink reference haha
hmm... just found the same set of wheels i want (albeit in a different colour, and without tyres) brand new for $90 more than i was gonna pay for use ones... really not a fan of the colour though...
was just reading a thread on ns.com
1800 defects in the last 8 days!! hahaha WTF!
would like to know what suburbs this is happening in!
i know the west subs have cops galore!
You said they said they heard? NS.com is hardly a reliable source. :down:
I have a soft spot for Capellas lol,
So badly want something old school Mazda with a 13bt in it.
Or a ke10 with a 13BT
Faaark yeah the 200m powerskids would be awesome
Edited by Weezy
Many years ago, I helped a mate fit a 12A into a KE10! Last I saw of that project he was getting it wired up. Don't know how far he got. But even a 12A in something as small as that would have been fun!
    • You know, that is exactly the thing that I was thinking a coupe of hours ago. I even had a plan for a meme, involving one big one, another big one, and the Old El Paso girl saying "¿por que no los dos?"
    • NoS, 2 of the big ones.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
