Taking the wife and 2 year old today .... should be fun blowing his little mind with all the animals and his first real kiddy rides :down: - I actually can't wait.
cam just see it now after 12 hrs at the show mrs nightcrawler and son .......can we go home now?.....night crawler nah just 10 more laps on the gokarts lol
Have you dropped what wheels your actually buying yet? if not...
Do tell please?
nope and nope. people are gonna have to wait until i rock up somewhere with them on.
oh, and if dale wanders through, theres a ceffy x-member for sale on ns now.
Edited by scandyflick
Fu*king hoons. Over night some red car has gone sideways around the corner and went straight into the fence at work. We only got 30m of it replaced 3 weeks ago when someone else went into it. A poll has been ripped out the ground and just missed a concrete wall by a metre.
Called the council and they don't wanna know ya. Getting till the stage where we have to spend money on making concrete walls to stop these guys, as our insurance company has almost had enough. It's happened roughly 16 times over 10yrs.
End rant.
damn not good to hear about that luke....some people just need to save up and take it to the tracks
But why blow $200 or so on a track day, when you can blow $400 on your excess! :D
Speaking of track days ... Saturday 19th of this month, I'm gunna try and sneak out to a ride day at Mallala. Gotta setup my 250 and might be the only chance I can do it before the next year racing season. Who wants to see Ruby crash??? :(
Well the weeked has come early for me. I was rostered on to work 4pm - midnight today, but I recieved a sms from my boss saying afternoon shift is cancelled. Its not all joy for me - I'm casual!!!
http://www.news.com.au/story/0,27574,26025279-421,00.html
if i was an olympian, i sure wouldnt f**k it up by being such a dickhead. it baffles the mind.
http://www.news.com.au/adelaidenow/story/0...5006301,00.html
they are human afterall :P
    • Oof, I will forevermore have those shredded gears in mind whenever someone talks about showing mechanical sympathy towards their car. Thanks for the photos, fascinating stuff!
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
    • I don't believe I posted pictures of the second oil pump pickup I added so here they are. Data shows it gets oil pressure up to the relief pressure much earlier in the RPM. Is that important? Not likely... This was just another attempt to fix the bearing issues.   I also heavily opened up the inlet to the pump since it now had to flow oil from two pickups. I believe the diameter increased about 1/8".
