How often do you see another blue R32 GT-R? ahahaha
not that often which is why i get a lil panicky when i do :( have had to make the phone call home twice now to get someone to check if its still there to help me chill :banana:
I think I remember Dave telling me to go for Cusco's.....?
yup. cusco or jic.
There we have it. Dave :banana: Cusco
hard not to. cusco > your mum.
and get some decent offset.
Why would you listen to someone who has never owned a skyline??? :(
haha, cause i know what im talkin about...
... occasionally.
For all your offset & suspension needs, PM Scandy :) The fitment guru aha
exactly.
shame im going for a weaker offset with my next set of wheels.
I think JIS have a set of JIC without spring rates listed.... :)
that they do. they also stock brand new jic fas and tar coils.
There are lots Kye. What, specifically, did you have in mind?
Look hard enough and you can find a 32 GTR in need of some TLC.
I know of a 4 door 33 for sale :)
has to be clean, manual but doesnt have to be a skyline or even an import but would perfer it. dont care about mods just has to be clean and no bull shit.
ive spend the last month so far looking at cars which the owners say once i ask the condition, "oh yeah, its only got like 1 or 2 scratches and thats it man!"
drive all the way up to the northern ghetto and find myself looking at a giant pile of bog and shit with wheels.
and already have a 33 4door with a forged 26 init and im bord with it haha
the man has a forged 26 and is 'bored with it'
f**k that, get him a psychologist
theres something wrong with his grey matter
-D
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
