Just heard a dark coloured nissan skyline was used in a hold up over night.
I assume its the stolen 33 getting around.
Yeah ... wonder how the media will spin it?
"Hoons turn to new wave of crime!"
You sure they werent stealing petrol from the tankers :P
sounds like FNF is in adelaide
Quick (dumb) question ...
Where is a good place to buy one of those baffle inserts for JunBL mufflers? (approx 5" outlet)
Ebay? ... or just go to someone like AAA. They should have something in stock yes? :(
just head out to one of the exhaust shops Roo....they should have it in stock if not then they should be able to make one up for you in no time
Thanks Krishy. I just didn't want to waste a lunch break taking a dead end. :(
yeah Dan, not just any RB30, but OS Giken RB30 .... just the blocks alone are $30k .... and he has bought many of them .... still has a brand new one sitting under his workbench under a sheet if I remember correctly ....
RB30 and RB315 Race engines
The ultimate upgrade for your RB26, these complete pre-assembled bottom-end kits are rated to handle power outputs up to 1400hp.
The RB30 features 86mm stroke with a forged chrome-moly crank, forged chrome-moly SCM steel H-beam conrods and forged 4032 aluminium 86mm pistons. It is made using a new Nissan block and specially designed spacer and liner kit. Special features not found in a normal RB26 include an 8-bolt flywheel pattern*, 22mm gudgeon pins and 23mm rod bearing width. Nismo black metal crankshaft bearings are used, with specially designed crank cap bolts. The bottom end is supplied complete with a metal head gasket, specially designed head stud bolts, adjustable timing gears, tensioner pulley and longer timing belt.
The new RB315 features 89mm stroke and 86.5mm pistons for 3138cc capacity. Normal combustion chamber volume comes to 10cc, but specially shaped pistons can also be custom-ordered. The RB315 is built using an N1 block, with the same specially-designed spacer and liner arrangement as the RB30, with an oil restrictor and piston cooler jets already fitted.
OS Giken RB30 $29,900
OS Giken RB315 $31,900
*An OS Giken clutch must be ordered to suit the crank in these engines
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
    • The funniest part I saw, was someone would bitch and moan on FB about something, Andy would be the one to respond, asking for more info, if he could contact them, what the engine setup is, what their config file was, and 95% of the responses were people just going "der! It doesn't work" and Andy going "What doesn't work?" And then going "The firmware!" And they'd go around in circles as no one could ever give information, and Haltech couldn't fault things on the bench, (especially when people wouldn't give any specifics).   Many moons ago, when Andy was back at e420c stage, he reached out to me, and asked me to test different plug and play looms for him (already had an e420c in the car on his V1 PNP loom). And he kept asking me, as I was competent enough to be able to give him some specific feedback on what was/wasn't working, how to replicate the faults etc, and work through things with him. Most people are terrible at answering the questions they're asked, or being able to provide quality feedback other than "it doesn't work".
    • I say it often, none of this stuff is really Skyline-specific per se. But in general there's not a lot of people who actually know what they're doing. A lot of people charging like they do. Agile software development probably isn't the greatest idea for an engine controller.
