It's only working intermittently for me as well, they were having some problems with the FS section on new version and Loz is working on fixing it so perhaps he's just in the middle for doing something so the access is restricted
NS has crashed completely now
anyone else having the slowest f**king afternoon ever?
ever had to book in for a haircut, and had to be booked with one of the apprentices because the owners are fully booked? chewing nails.
harden the f**k up and get a number 1 :D
-D
Aren't there usually cute apprentice hairdressers though?
Damo likes they male hairdressers....so i have heard
he's taken. he's not allowed to look.
no no no Jarrad.....he can go window shopping just can't buy
i love my local hairdresser. shes crazy hot. dumb as shit. and always with the boob rub...
... i think im due for a haircut.
and a boost juice. mmmm, boost juice.
Can't remember the name of the shop but on the lower level of TTP (near Kmart) the female hairdressers are pretty impressive.... I miss living 5 minutes from TTP :blink:
The one near kmart... is a barber shop full of old dudes.
Just Cuts near the food court maybe? :thanks:
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
