Abe I'm 99% sure it's the video card. It stuffed up about a yr ago, replaced with a second hand one where the fan wasn't working properly for it.
Any idea where to get a basic video card from? Don't use the comp for games etc so just need a basic one.
Cheers.
ur diagnostic skills are fail... =P
if i was a betting, wow, i'd probably put my car up on it not being the video card =D
could be soo many other things making it do that... number 1 is the power supply! i'll also throw my hat in the ring and offer u some free help, just lmk
ps. hoodie thread up soonish
Luke, i just worked out what it is... =D
but i'm not going to tell you what it is because if you try to fix it and mess up you could end up killing stuff!
however i will say this, whoever you take it to will set it up and it'll probably turn on first time, straight away and u'll both be like "hu?" =P
^ what a graph card that's not seated correctly in it's slot?
wow, i should actually start taking bets with people on this! =P
no, as i said before, nothing to do with vidoe card... unlikley that one would just randomly pop out!! =\
Tell tell..... I'll give good prices on jap stuff lol
just drop round and i'll fix, fix!
edit: and coz u get me good prices i wont slug you the $40 i would to a customer for fixing it =P
Edited by Fishpaste~
With big turbos cams can make you up to 50kw depending on the size of the turbo and the amount of head work done as they allow you to move the turbos into their efficiency range, but like chad said with small turbos they won't affect peak power much but will allow you to move the power around the rev range and can get you some nice gains on torque.
Here's some graphs from when we were playing with the cam gears on my car.
cheers man, might go ahead with these os cams
see what willal can do with them once i get a new exhaust fitted
Hey guys, I was wondering if any of you have heard of GT Autosound in Glynde, and if they are a reputable workshop. Thanks in advance.
yeah their pretty good their man and reasonble prices with what you get out of it
Sweet. How long u reckon it would take? Have to head down to Marino around 9am so could pop by after that?
Cheers.
prob 15 mins all up... thing is i'll be at uni from 9 till 4 tomorrow, then have district basketball
so either drop round tonight or tuesday!
u gonna be up for abit still? If u are I'll pop around soon.
George and Theo are excellent guys. Havn't had any work done by them, but never heard a bad word about their work :ph34r:
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
