i now have a box of stupidly expensive earls bits and pieces to go on the s14. just gotta pic up one more adaptor fitting from outlaw, and 2 90 degree bends from somewhere else and ill fit it all up.
Edited by scandyflick
Did you get it all through Outlaw's Dave?
hey all.
does anyone have an account with motor traders? can get cheap parts?
need 4x hec716 (ls1 coilpacks)
going external setup on the CA18det..
if anyone has hook ups let me know :P
also,
took my car to get some work done/oil cooler fitted. picked up the car and oil cooler lines were cut to "make them fit better (too long apparently)"
once they were cut the workshop couldnt get fittings to go on them so now i have an oil cooler with cut lines and nothing to connect them with..
what can i do? claim them against the business?
cheers
You won't be able to claim against the workshop as they will say that the problem was caused by the cheap lines. if they had provided the parts then you would have a claim. bring the lines to me and i'll get the fittings on them.
Gotta love the justice system.
The police caught the guy who broke into my parents rental property, got locked up but then released on bail a day later. Found out he was released last week on bail for beating a guy up. They can't lock him up for longer as this offence is totally different to the others.
What a load of shit.
Hey guys I have a quick question, I did search and did find an answer but I just wanted to see if anyone has a difference of opinion. If I am fitting aftermarket CF N1 Vents to an aftermarket FG bar, what is the best method of holding them in there?
Cheers :)
nice big plume of black smoke across the northern burbs - pgs (plastics granulating factory) has caught fire in kilburn
i could see the plume from semaphore... 30 metre tall flames as i drove past.... fireys are worried cos there are lpg tanks nearby and folks have been evacuated from their houses... looks like every cop in adelaide is down there
sooooo
go for a cruise if you're bored, they got bigger fish to fry tonite lols
-D
Unfortunately, thats a (fair) case of innocent until proven guilty. Until the court case prosecutes him, any further (accused) offences are to be treated without prejudice. Why cop the second offence harshly is you're innocent of the first offence?
Thats just the way things work.
I know what you mean tho. A close friend was killed in an auto accident by a crim who was on bail for murder at the time. His first offence (altho prosecuted for it) was not taken into consideration in sentencing him for killing my friend. He got 7 months added onto his already 7 years (for murder)!!! So he basically got a freebie before going to jail. FAIL
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
