i now have a box of stupidly expensive earls bits and pieces to go on the s14. just gotta pic up one more adaptor fitting from outlaw, and 2 90 degree bends from somewhere else and ill fit it all up.
Nice work, good quality gear right there!
This is where i fitted mine as i was telling you about. Not sure if you have the same amount of spare space.
Photos!!!!!!!!!!!!!!!! :)
Penny, I'll start a separate thread for this and stick the pics I do have there. Pics are limited due to the strict rules even I have to follow.
nice big plume of black smoke across the northern burbs - pgs (plastics granulating factory) has caught fire in kilburn
i could see the plume from semaphore... 30 metre tall flames as i drove past.... fireys are worried cos there are lpg tanks nearby and folks have been evacuated from their houses... looks like every cop in adelaide is down there
sooooo
go for a cruise if you're bored, they got bigger fish to fry tonite lols
-D
We were commenting on this before, we live 36kms north of the CBD and it was clearly visible.
Oh and also Damo, I searched and found using sikaflex works also. So I will do that I think. Cheers for the input :)
This is where i fitted mine as i was telling you about. Not sure if you have the same amount of spare space.\
<snip>
definitely happy with the quality of the stuff, but shit, doesnt seem like a whole lot for the dollars.
and yeah, i doubt i have anywhere near that room. will know better on wednesday when i hook it up i spose.
you should have Dave, well that depends on what row cooler you are running.
I know mine is a different model S-Series but this is where i put mine (had to cut the hole though).
just went and had a look, between the washer bottle and my intercooler pipe, i have no room to fit another core.
so options i can see, mount on the passenger side (but that requires yet more hose) or mount in front of the radiator (behind the i/c), or in front of the i/c (means trimming the bar a tiny bit more... which i gotta do anyway. winrar?)
PGS is the company that supplies my company PPI with granulated plastic to which we melt down and turn into pipe,
Wonder what will happen now that PGS has caught fire and how long they will be out of production.
This could be interesting
well considering the fire was 40 metres high, 40 metres square wide, and i could see it from the beach, i daresay man it'd be a good thing if u trimmed ur resume and put it out ASAP
dont ever wait for companies to abandon you. get ur foot in the door before it hits u on the way out! (personal opinion)
-D
Yeah, we get our granulated poly from other companys too, 80% of it comes from PGS, I would like to think I'll hardly loose my job over this but I am looking for other employment as this is a 'for now' job that my father got for me (hes my supervisor).
got any IT experience ?
i know of two companies looking for engineers, but u need to have a fair bit of xp.
-D
Got smoke?
Taken from the intersection of grand junction and south road. i got closer and the flames were visible
i hope they catch the little douchebags responsible... apparently one teenager has been apprehended
good.
-D
    • I dunno man, that VX S with 200,000 k's is still hanging out for 1.5 I reckon the R34 is the better buy, personally.
    • Dang, doesn't even include on roads.
    • Only in a market where OBD was a thing. The rest of the world was quite happy to let the US EPA only affect US cars for quite a while. The* problem with datalogs is that unless you are very familiar with what every trace should look like, on their own and as an ensemble, you can and will see weird shit that can and will lead you astray, not realising that what you are seeing is the normal consequence of various transient inputs. *Really, "a" problem, as there are of course many other problems too. Look, these cars are so bloody simple that if it is missing or stumbling, the obvious thing is to break out the old mental diagnostic list and just go do all the things that you know you should. After proving that the plugs are clean and sound, ditto the coil stalks, coils, loom connectors, etc, and then making sure that there is fuel pressure at about the right numbers (while driving!, not while sitting in the garage free blipping it), then maybe you go looking at AFM voltages, manually testing the igniter, putting a scope on the CAS, etc. Then you're into pulling the injectors for a spray pattern look-see and perhaps a clean, squirting carby cleaner around the inlet manifold looking for leaks, and all the more annoying and esoteric, but still common as muck faults that these things have. I wouldn't ever bother looking at the trims, as they are usually bullshit on these old clunkers anyway.
    • Jousting sticks! Tell 'im he's dreamin!
    • GTR owners are wankers - 2025
