dale, where did u get your catch can made?
want a setup similar to yours.. with the breather etc..
cheers
It's just a Greddy copy can that i got off eBay for $45. i added the filter though, i just drilled and tapped a hole then used a -8 barbed fitting and a filter that i got from Autobahn for $8. If you do the same though make sure you use a -10 size fitting as the filter is to small on mine and when i put the car back together i'll be making it bigger.
I have to make up the brackets to hold the can as well.
cheers
yo, head down to see niko at smooth.
he made me a perfect catch can for my ca in the drift car.
big and user friendly and didnt cost much at all and they fitted it up with new lines since my old one was too small.
Took some pics of the new toy yesterday .... pity it was raining and filthed it up before the photos (despite it being washed 2 hours earlier :) )
Fave photo
Very nice - I've seen a few people use that one - where is it at?
I'm having injector issues AGAIN. 3 weeks after replacing 2, another 2 (not replaced) have started leaking. pissed off
and i called main north nissan. OEM nissan 444cc injector = $437 EACH!!!!1one... and then I find a place in japan that can post me a set of Nismo 600cc's for $990. Geee, whatever shall I do? :happy:
Just sucks - have to drive the car as little as possible in the meantime. *grumble* already the car is going in this weekend to get the spoilers and bumpers painted, couple dents removed, the rear bumper reo fixed from last sundays rear-end accident, calipers and hubs powdercoated and the oil relocation kit relocated (its in a really daft place atm, very low to the ground - good for capacity but not great when you go to park and have a concrete bollard hit the oil filter...)
-D
-D
Get a set of 570, 660 or 750's off these guy for $780. And they're in Australia.
http://www.injectorsonline.com/indivprod.p...=74&scid=12
Edited by D_Stirls
just go for a 3071R Matty, very similar compressor but already fitted with the T3 rear.
3071R wont have the responsiveness i want though (its going on a basically stock internaled RB20). I mean, we could make the new mani with a T25 flange, but that stuffs me for future upgrades
*edit*
Abe, 3076R is worse for me lol
Edited by Matty 31
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
