The Sa Wasteland
Cubes
 Share
Did you not say a RB25 hybrid? Or is that the type of turbo, a hybrid of a RB25 turbo, not the engine.
I am putting a 3076R on a stock RB25...but it will have 740cc injectors, and a kickass ECU. Just a matter of booking the car in, and handing over about $1.5k to have it installed and tuned :P
The difference in response between the 3071 and the 2871 would be less then 200rpm but will give you more headroom for future mods. Infact Powertune in NSW and Street Forced Performance in Vic have developed a 3071 kits for SR's that are as responsive as a 2871r if not more responsive. I'll find the thread;
EDIT!! Here you go
http://www.nissansilvia.com/forums/index.p...howtopic=406078
Edited by D_Stirls
Took some pics of the new toy yesterday .... pity it was raining and filthed it up before the photos (despite it being washed 2 hours earlier :P )
Fave photo
I was outside in the rain, rinsing my car off, so once the rain stopped i didn't have any dusty watermarks, the joys of living off a dirt road.
random "update" of my "progress". just copied and pasted from my ns thread cause im lazy.
i decided id stop being lazy and start fitting my oil cooler today.
i also decided id go with a relo instead of just using a sandwich plate. having trouble picking a spot to mount the relo though, so if anyone has any suggestions, that be great.
a view that is becoming all too common with this car...
new billet alloy earls relo block;
roughly where the core will sit;
and where the lines will be routed;
the mess of fittings off the permacool spin on adaptor;
(that bung in the straight fitting is a port for the temp gauge, blocked up til i get it...)
almost finished, need to mount the relo block, buy a filter, buy 1x 90 barb fitting, 1x 45 degree barb fitting, some straps of aluminium to mount the core, and itll be done.
so the kit now consists of a permacool spin on block adaptor, an earls billet relo block, an earls 19 row cooler, a whole bunch of random fittings, and 3 metres of flame proof line. bit more than i started with. lol.
and a random lol;
Edited by scandyflick
im totally bringing my gameboy out of retirement for pokemon!! WOOOT
lol I cranked out the N64 for Zelda the other day. Still got my SuperNes aswell including all the classics like super Mario world, donkey kong 1, 2, & 3, yoshis island, plus many more.
if you get modded xbox the old 1 anyways u can get any nes, super nes, ds and some n64 games on it.
works much better than using keyboard on pc ;)
and there are these things called emulators that prob work better than your webpage for it.
mario allstars ftw
 Share
    • I am using a pull nismo coppermix twin in an r34 getrag box, had both the standard slave and  then the nismo one. Adjusted pedal to get bite point how I wanted , it is on the higher side, but would fully disengage past half way down.  I also read that the nismo slave won't work but I had no issues with the stroke, might become one later as clutch wears but 2+ years of happy motoring so far.  Take the above as one input only, specially as my setup is a bit unique in that I am using an S15 clutch master , cefiro clutch pedal, custom braided clutch line. Lots of variables at play.
    • Oh for sure, I'm just recounting my thoughts 😎 I'm not what you've got there to fuzt with.... likely my first idea was on the money -- rebuild or replace connectors. You can get a lot of connector stuff here  -> https://www.rapidcables.com.au/ Didn't look in the boot of mine, because I replaced these when I renewed the pump (plastic of connectors had gone brittle) edit: what I used... https://www.efihardware.com/products/2120/Deutsch-DTM-Connector-Kit-6-Pin ...cheaper... https://www.ebay.com.au/itm/364900039138
    • In no way was i suggesting it’s your fault mate. The trailer cable has a plug that I removed. I will have a closer look, but I did remove the trailer wiring cable with the tow ball as I don’t need it on my silo. i have replaced the fuel pump already there’s no need to remove the cradle again I can see the wire colours from it in.
    • Mint. Good to see another GTSt getting love and coming back to life. Did I miss what colour you are going to wrap it?
