The Sa Wasteland
Cubes
 Share
Did you not say a RB25 hybrid? Or is that the type of turbo, a hybrid of a RB25 turbo, not the engine.
I am putting a 3076R on a stock RB25...but it will have 740cc injectors, and a kickass ECU. Just a matter of booking the car in, and handing over about $1.5k to have it installed and tuned :P
The difference in response between the 3071 and the 2871 would be less then 200rpm but will give you more headroom for future mods. Infact Powertune in NSW and Street Forced Performance in Vic have developed a 3071 kits for SR's that are as responsive as a 2871r if not more responsive. I'll find the thread;
EDIT!! Here you go
http://www.nissansilvia.com/forums/index.p...howtopic=406078
Edited by D_Stirls
Took some pics of the new toy yesterday .... pity it was raining and filthed it up before the photos (despite it being washed 2 hours earlier :P )
Fave photo
I was outside in the rain, rinsing my car off, so once the rain stopped i didn't have any dusty watermarks, the joys of living off a dirt road.
random "update" of my "progress". just copied and pasted from my ns thread cause im lazy.
i decided id stop being lazy and start fitting my oil cooler today.
i also decided id go with a relo instead of just using a sandwich plate. having trouble picking a spot to mount the relo though, so if anyone has any suggestions, that be great.
a view that is becoming all too common with this car...
new billet alloy earls relo block;
roughly where the core will sit;
and where the lines will be routed;
the mess of fittings off the permacool spin on adaptor;
(that bung in the straight fitting is a port for the temp gauge, blocked up til i get it...)
almost finished, need to mount the relo block, buy a filter, buy 1x 90 barb fitting, 1x 45 degree barb fitting, some straps of aluminium to mount the core, and itll be done.
so the kit now consists of a permacool spin on block adaptor, an earls billet relo block, an earls 19 row cooler, a whole bunch of random fittings, and 3 metres of flame proof line. bit more than i started with. lol.
and a random lol;
Edited by scandyflick
im totally bringing my gameboy out of retirement for pokemon!! WOOOT
lol I cranked out the N64 for Zelda the other day. Still got my SuperNes aswell including all the classics like super Mario world, donkey kong 1, 2, & 3, yoshis island, plus many more.
if you get modded xbox the old 1 anyways u can get any nes, super nes, ds and some n64 games on it.
works much better than using keyboard on pc ;)
and there are these things called emulators that prob work better than your webpage for it.
mario allstars ftw
 Share
    • Just looking at the instructions for these Efi hardware terminals, is anyone able to explain to me why the diameter of the hole must be specifically between 8.1 and 8.2 mm? If the post is 6mm, and you drill say a 7mm hole, how could this possibly cause an issue?  In any case, the more I read these instructions, the more I think I want to give them a go.  https://www.efihardware.com/download/237/866-033_M6_Bulkhead_Terminal_High_Amp
    • Okay it seems there's a slight design difference there with the hex which will do nothing at all. The ones I had were the EFI Solutions round ones. I was able ratchet the nuts with huge torque and they were flat and FIRMLY into it. You could say they became part of the lid, given they physically melted into it. It doesn't get any more firmly attached than that! The heat generated is enough to melt the plastic insulators. I agree, you would think Walbro would use wiring in their own pump with enough gauge to handle the heat their own product creates, but it just doesn't seem to be the case long term. I suppose it's possible that mine only shifted towards the end of their 10 year life before melting through, but that said... it can shift again, a nut can come loose again. The solution is a different type of plug, that is held in mechanically and can't shake loose and self-create a bad connection.
    • Those exact ones, with the hex head on the plastic insulators and the metal flange?
    • I nearly feel this is the issue, those insulated terminals are aids to crimp correctly.
    • These are the ones that I melted. You need the FPR kit, nothing else will work. :p
