Did you not say a RB25 hybrid? Or is that the type of turbo, a hybrid of a RB25 turbo, not the engine.
I am putting a 3076R on a stock RB25...but it will have 740cc injectors, and a kickass ECU. Just a matter of booking the car in, and handing over about $1.5k to have it installed and tuned :P
The difference in response between the 3071 and the 2871 would be less then 200rpm but will give you more headroom for future mods. Infact Powertune in NSW and Street Forced Performance in Vic have developed a 3071 kits for SR's that are as responsive as a 2871r if not more responsive. I'll find the thread;
EDIT!! Here you go
http://www.nissansilvia.com/forums/index.p...howtopic=406078
Edited by D_Stirls
Took some pics of the new toy yesterday .... pity it was raining and filthed it up before the photos (despite it being washed 2 hours earlier :P )
Fave photo
I was outside in the rain, rinsing my car off, so once the rain stopped i didn't have any dusty watermarks, the joys of living off a dirt road.
random "update" of my "progress". just copied and pasted from my ns thread cause im lazy.
i decided id stop being lazy and start fitting my oil cooler today.
i also decided id go with a relo instead of just using a sandwich plate. having trouble picking a spot to mount the relo though, so if anyone has any suggestions, that be great.
a view that is becoming all too common with this car...
new billet alloy earls relo block;
roughly where the core will sit;
and where the lines will be routed;
the mess of fittings off the permacool spin on adaptor;
(that bung in the straight fitting is a port for the temp gauge, blocked up til i get it...)
almost finished, need to mount the relo block, buy a filter, buy 1x 90 barb fitting, 1x 45 degree barb fitting, some straps of aluminium to mount the core, and itll be done.
so the kit now consists of a permacool spin on block adaptor, an earls billet relo block, an earls 19 row cooler, a whole bunch of random fittings, and 3 metres of flame proof line. bit more than i started with. lol.
and a random lol;
Edited by scandyflick
im totally bringing my gameboy out of retirement for pokemon!! WOOOT
lol I cranked out the N64 for Zelda the other day. Still got my SuperNes aswell including all the classics like super Mario world, donkey kong 1, 2, & 3, yoshis island, plus many more.
if you get modded xbox the old 1 anyways u can get any nes, super nes, ds and some n64 games on it.
works much better than using keyboard on pc ;)
and there are these things called emulators that prob work better than your webpage for it.
mario allstars ftw
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
