The Sa Wasteland
Cubes
 Share
i think they call it 'sex spec', and apparently its the modding style australia is known for.
Houston Tx. Google 'slab'
http://www.urbandictionary.com/define.php?term=slab%20party
A common thing in Houston, Texas USA. This popular phenomenon occurs almost anywhere in Houston with a big parking lot. It is commom to see many slabs poppin' trunk, 15's bangin, sittin low on gold D's wrapped up in Vogues. Slab parties are popular among the local rap scene and its fans in Houston. Slab parties might also be found in other parts of Texas and the south. For more information, please see slab
Like so
-D
^^^^^^them some nice dinner plates he got
sex spec started in 1 of those ignition dvd's thought it was lame then still think its lame now.
n does the owner not have to play a ball game to have a 'baller' car :D
Edited by Inline 6
Mmm... Andrew special... Speaking of which, his new workshop is coming along quite nicely
imma srsly have to get that cat to make me some exhaust manifolds and dump pipes once i get my n1's
-D
Luke, did i see you the other day crossin the road to go into st morris bakery?
looked like you, but i was too busy checkin out a hotty running down the road in those skins pants lol
St Morris Bakery? If you mean St Peters then yes, and if so, that I think I know the hottie you were talking about cos I checked that shit out too :D
 Share
    • I am using a pull nismo coppermix twin in an r34 getrag box, had both the standard slave and  then the nismo one. Adjusted pedal to get bite point how I wanted , it is on the higher side, but would fully disengage past half way down.  I also read that the nismo slave won't work but I had no issues with the stroke, might become one later as clutch wears but 2+ years of happy motoring so far.  Take the above as one input only, specially as my setup is a bit unique in that I am using an S15 clutch master , cefiro clutch pedal, custom braided clutch line. Lots of variables at play.
    • Oh for sure, I'm just recounting my thoughts 😎 I'm not what you've got there to fuzt with.... likely my first idea was on the money -- rebuild or replace connectors. You can get a lot of connector stuff here  -> https://www.rapidcables.com.au/ Didn't look in the boot of mine, because I replaced these when I renewed the pump (plastic of connectors had gone brittle) edit: what I used... https://www.efihardware.com/products/2120/Deutsch-DTM-Connector-Kit-6-Pin ...cheaper... https://www.ebay.com.au/itm/364900039138
    • In no way was i suggesting it’s your fault mate. The trailer cable has a plug that I removed. I will have a closer look, but I did remove the trailer wiring cable with the tow ball as I don’t need it on my silo. i have replaced the fuel pump already there’s no need to remove the cradle again I can see the wire colours from it in.
    • Mint. Good to see another GTSt getting love and coming back to life. Did I miss what colour you are going to wrap it?
