The Sa Wasteland
Cubes
 Share
coz he was in breach position and was compressing up
in wendy's ribs, due to his size.
they usually take them at the end of the 38th week with c sections anyways.
Yup that'll do it lol!!
Glad things went well! Definatly an eye opening experience isnt it, lucky you didn't have to go through the tradational birth stuff first!
Hell, while you're there, why not! :bunny:
That's my way of thinking!
just thought id pop in to make a little announcement,
our new baby boy, Lachlan James was delivered by c section at 2.45 pm yesterday,
at 38 weeks he still weighed 9 pound 8oz and 51 cm long,
both mother and baby doing very well!
cheers!
:P
Damn good news mate! Glad to hear all is well!!!
so whos interested in paintball? I wanna organise one closer to christmas or just after, when the weather gets a bit more predictable.
Farkkkk Yesssss to paintball!!!!! :bunny::P
Andd big congrats to craig for the new addition to the family and hopefully future sau member hehe!!!! :P
Edited by wnted1
Finally had a chance to head down to Regency and change over my rego on the V35 today. Hooked up some nice plates for it too (well I like them) .... have to wait 2 weeks for them to be made though.
Also fitted some goodies incl. Nismo rad cap, Nismo oil filler cap, and Carbon Fibre bonnet struts - they are bloody awesome!
Congratulations Craig!
And Pete, its just i know a guy with a fairly potent VH Pacer 6 Pack, and know there aren't or were too many floating around. This thing embarrassed many an exotic owner !
congrats craig! :)
wheres the cf cover?
and what plates did you get?
Wow. These XD9's are a very expensive porch ornament.
this surprises you?
Ahh OK.....if it's got a cut & shut Customline 9" rear end then yep, it's my old ride
Woo Valiant starts :) After 5yrs of it sitting there it starts woo.
Anyone know what oil filter they take, what oil is best, what spark plugs and what coolant is good for it?
James im looking at you lol
Z9 Filter if it's a 225, 245 or 265 6 cylinder, which is actually the same thread as RB's use but a lot bigger.
Our old dirt circuit Open Wheeler was running a Jeff Juring built 265 HEMI making around the 350HP mark.
Edited by D_Stirls
 Share
    • Hi there, after a quick google search I found this topic as I am also relocating the battery to the boot of my 1998 GTT. I was just wondering how you got on with installing the re-routing and specifically the installing of the harness protectors? How do they attach? Are they just a simple "click-in" affair, or do they attach with bolts? Does the GTT have all the necessary fixing holes for them, for example, where they locate on the chassis? Any help you can provide would greatly appreciated.
    • Thanks mate, yeah I've heard that alot and i am definitely regretting using the 25 Loom now, i have gone through and traced all the plugs from the 20loom and re wired them into the 25 loom, I have currently got Crank, Fuel and accessory's working, just need to finalise the loom and run the wire for the Ignition (Spark) and it should be running, will update if i have any luck.
    • Cheers lad, when I head over there I'll give it a shot.
    • Stock less likely to carry one like that than urethane, but still can, especially if the bolts are not as tight as they should be. If it's making that much noise you should be able to use a hose as a stethoscope> stick one end in your ear, crouch down and wave it around the various possible noise makers and get someone to lift the front end at the guard lip.
    • Broken actuator rod. Could be one of a couple of them broken. Or, it's locked and the central locking actuator is broken/stuck or the actuator rods between it, the lock and the key barrel are jammed or broken similarly. You'll probably need a locksmith/mechanic who is experienced with using slim tools to reach down next to the window glass to manipulate the mechanism. That's assuming that it is not so severely jammed/broken that nothing useful will move.
