$220, that was a touch up on an existing tune.
Sweet. Now that I got my fueling and CAS fixed, I wanna get the Stagea on the rollers to get back those lost ponies.
Did a compression check a while ago and thankfully no compression loss or blown rings etc. Thankful that I babied the stag around when I knew it wasn't running right.
I wanna get to that turbo/dump gasket leak this weekend too.
damo that boost curve looks consistent with the r34 turbo
a really good ebc may fix up the peak & hold boost, or better yet a fully tuneable computer
as it is it isnt a bad tune...
i have a power fc, but a shit boost tee.
ah simple then, save for the power fc boost controller - scour ebay, JPS Trading Ltd is a good trader to search thru
you can see where the boost T isnt cutting the mustard from 80-120kmph
see how a decent boost controller works better ?
edit: the dropping off of boost was from restricted exhaust, much flatter now at the pointy end of the graph
tune of new piggyback ecu on 8th Oct, update then with a 250+ kw tune map
If you still have the factory boost solenoid in line then i expect if you had a your boost graphed then this is what it would look like (This is a mates figure from his 33). How much boost are you running? Is yours an auto or manual because that figure looks a bit low to me (depending on boost). The other thing that would be playing a part in the hole is the VTC timing not being perfect.
Edited by D_Stirls
still dropping off - but fuelling is the issue here
again, on 8th oct bigger injectors slot in, so will update some graphs for discussion.
Id suggest damo that a better ebc will do the job well. p-fc boost controller.
Where is the dropping off boost shown?
The graph says 10-11psi, when he rang i said around 10.5psi would be fine, and i assume thats what its on, hard to read from factory bar guage. Its a manual.
Its a turbosmart bleed valve, and always has lost boost from 4000ish to redline since it was fitted.
:D This is gonna sound pretty gay. But for some reason Damo, You were in a dream of mine last night. And you drove a VT commodore.
Thats sweet Craig. and by "drove a VT Commodore" i hope you mean "watched you have sex with Megan Fox"
    • I once hit my knee on an exhaust on my sisters Suzuki Sierra after she drove it her *normal* way. My knee looked like porridge for weeks. Bec and my daughters never go near this car. I can see one of my dogs losing an ear though. 🤔
    • Nice, love a good GTS-t.  IMHO the factory body kit with the 'aero' front bumper is perfect. Can't improve on it unless it's a GT-R. But it looks like you changed it to the normal bumper?
    • Easy solution to both of those. Put a split bit of garden hose on each one. Attractive and practical!
    • So I guess the next thing to do will be to discuss whether to create a new section of the forums to hold the library (boo hiss?), somewhat undoing the recent tidy up, or if there is a bolt on wiki module for Invision? (I must profess ignorance as to what has been done, what it might cost, etc. I have only briefly googled and seen discussion on adding it.) Or is a wiki even the best way to do what I'm talking about? It possibly isn't. Given that we're trying to re-display forum content, it probably needs to be presented as forum content in forum format, and a wiki would probably struggle with that. A wiki might still be the best way to do some other things, so I'll keep the idea simmering if we don't use it here. Back to the library as "part of the forums". Would we do a single new library? Or put a library thread in each section? Pluses and minuses for each of these, surely. Would we do as I originally suggested, and make the first post in the library be the total of the library, with any reply posts just being the inputs and suggestions I originally posited? Or would we allow posts to accumulate one after the other, each containing additions to the library? Maybe the first post is still an index or something. It's all sounding horribly more manual and messy than my original brain fart. But I hope there's some other good ideas floating around - because every time I come up with a new one of my own I immediately see problems with it.
    • Tips look fine to me......but Boring stuff: Legalities - Vehicle standards notes that exhausts cannot extend to a point where they could cause injury Scary stuff: Mrs cuts open her shin putting stuff in the boot (ensure you have some bandaids and shiny jewellery handy)
