The Sa Wasteland
Cubes
 Share
$220, that was a touch up on an existing tune.
Sweet. Now that I got my fueling and CAS fixed, I wanna get the Stagea on the rollers to get back those lost ponies.
Did a compression check a while ago and thankfully no compression loss or blown rings etc. Thankful that I babied the stag around when I knew it wasn't running right.
I wanna get to that turbo/dump gasket leak this weekend too.
i have a power fc, but a shit boost tee.
ah simple then, save for the power fc boost controller - scour ebay, JPS Trading Ltd is a good trader to search thru
you can see where the boost T isnt cutting the mustard from 80-120kmph
see how a decent boost controller works better ?
edit: the dropping off of boost was from restricted exhaust, much flatter now at the pointy end of the graph
tune of new piggyback ecu on 8th Oct, update then with a 250+ kw tune map
If you still have the factory boost solenoid in line then i expect if you had a your boost graphed then this is what it would look like (This is a mates figure from his 33). How much boost are you running? Is yours an auto or manual because that figure looks a bit low to me (depending on boost). The other thing that would be playing a part in the hole is the VTC timing not being perfect.
Edited by D_Stirls
still dropping off - but fuelling is the issue here
again, on 8th oct bigger injectors slot in, so will update some graphs for discussion.
Id suggest damo that a better ebc will do the job well. p-fc boost controller.
Where is the dropping off boost shown?
The graph says 10-11psi, when he rang i said around 10.5psi would be fine, and i assume thats what its on, hard to read from factory bar guage. Its a manual.
Its a turbosmart bleed valve, and always has lost boost from 4000ish to redline since it was fitted.
:D This is gonna sound pretty gay. But for some reason Damo, You were in a dream of mine last night. And you drove a VT commodore.
Thats sweet Craig. and by "drove a VT Commodore" i hope you mean "watched you have sex with Megan Fox"
 Share
    • Hi there, after a quick google search I found this topic as I am also relocating the battery to the boot of my 1998 GTT. I was just wondering how you got on with installing the re-routing and specifically the installing of the harness protectors? How do they attach? Are they just a simple "click-in" affair, or do they attach with bolts? Does the GTT have all the necessary fixing holes for them, for example, where they locate on the chassis? Any help you can provide would greatly appreciated.
    • Thanks mate, yeah I've heard that alot and i am definitely regretting using the 25 Loom now, i have gone through and traced all the plugs from the 20loom and re wired them into the 25 loom, I have currently got Crank, Fuel and accessory's working, just need to finalise the loom and run the wire for the Ignition (Spark) and it should be running, will update if i have any luck.
    • Cheers lad, when I head over there I'll give it a shot.
    • Stock less likely to carry one like that than urethane, but still can, especially if the bolts are not as tight as they should be. If it's making that much noise you should be able to use a hose as a stethoscope> stick one end in your ear, crouch down and wave it around the various possible noise makers and get someone to lift the front end at the guard lip.
    • Broken actuator rod. Could be one of a couple of them broken. Or, it's locked and the central locking actuator is broken/stuck or the actuator rods between it, the lock and the key barrel are jammed or broken similarly. You'll probably need a locksmith/mechanic who is experienced with using slim tools to reach down next to the window glass to manipulate the mechanism. That's assuming that it is not so severely jammed/broken that nothing useful will move.
