The Sa Wasteland
Cubes
 Share
from 120 thru to 180 the downward line shows that it was dropping from 14.7psi down to 12psi at WOT in top gear
That's the torque curve not boost; and torque will almost always drop off in the top end as you have past the point of Max' VE (volumetric Efficiency) and rate of change of power has began to decrease i.e.torque.
Here's an example; these two print outs are of the same runs; one showing torque and the other showing boost. See how the boost is dead flat but the torque is still dropping.
Edited by D_Stirls
Thats sweet Craig. and by "drove a VT Commodore" i hope you mean "watched you have sex with Megan Fox"
hahah strange night indeed. One of those only half sleeping nights. Had the laptop next to me waiting for downloads to fin all night. Hence weird dreams.
I only really remember you being in my front yard. drinking. then kicking the wheel of your commodore with your foot.
I woke up today and thought to myself 'wtf'
i can't see how unless they are rated higher. First i would look at whether the factory solenoid is still in line if it is then bypass it and it MAY help a bit. But the others are right a EBC is your best bet as they minimise wastegate creep and do a much better job at controlling boost.
If you twist my arm i might even sell you my new one that has only done 500km since i'm looking and changing to a Turbosmart E-Boost 2.
P.S> so is your car Auto or Manual?
Its a Blitz DSBC Spec S.
That power is low then since your car is a manual.
you should be pulling a lot better numbers than that graph of my mates, because the only mods done to it were; Full 3 inch exhaust and FMIC, that's it. Doesn't even have a boost controller, Hence the boost curve . So it's running standard factory fuel and ignition maps it's just with the freed up exhaust and intercooler they run up to 12psi.
So even on 10.5 psi you should be closer to 200kw than you are.
Edited by D_Stirls
yeah stirls, I know its a torque curve, ... being my car and all the tunes etc I just happen to know at that point of time with that tune the boost dropped off as described
alls good now tho
:D
So if I were to put a FMIC on my car which is stock except for the 3" turbo back, I could go to 10 psi without any other supporting mods?
with his car that is what we found, though every car is different and if you have a look at the graph it's a far from ideal boost curve.
Also before you go out and start flogging around with your new found power is't probably a good idea it chuck it on the dyno and run it up to see if the AFR's are acceptable in your case. Nissans are generally VERY rich under boost though.
Edited by D_Stirls
I'm not interested in huge power figures and 'flogging' it but just want a little more acceleration. At the moment it hits the factory 5psi by around 3K RPM since the AM split dump and Cat have gone on, just want a gentle extra shove so to speak. I haven't done the hi boost mode mod to the car yet either.
FMIC, full 3" exhaust, I'd put 12psi through a RB25 anyday providing your injectors and fuel pump are in good enough to keep up which unless you have a good ear for pinging even sometimes you can't hear it I would do it all on a dyno so you can watch A/F ratos through out rev range and accurate manifold pressures (boost pressure).
Yeah, i only tuned it to 10.5psi to increase the life of the turbo. 12psi is at peak efficiency for a stock rb25 turbo.
Okay you know how sometimes you see car accidents and you think... how??
Well this afternoon, there was an accident in my suburb, which resulted in a Commodore suffering rear end damage next to a bent power pole. Sounds straightforward huh? But there was a car trailer with a car on it, upside down behind the Commodore - as in right behind - but the Commodore was on 4 wheels. Hope everyone was ok.
 Share
    • Its also very clearly made to take business away from https://theskylineshed.com/ which is legitimate and even has a physical address.
    • The 'About Us' got me ..  I added something to the cart and clicked 'check out' and none of the payment options in the footer (ie those with buyer protection) were available. Stay the hell away from this one.
    • No. Not true for any non-GTR R32. I think even the GTS4 has the GTSt knuckles with eye type lower shock mounts (as opposed to GTR fork lower shock mounts). The only R chassis in which something like the quote claim is true is the R34, on which the turbos have the fork type and the NAs have the eye type. **Edit: Actually I reserve the right to be wrong about the above statement. It might also be true on R33s. My memory on those shitboxen has faded too much.
    • It's a scam. It has all the telltale signs: - The "business" doesn't have a physical address or really any kind of information listed - It's using a generic online store website template - The prices are ridiculously reduced. To good to be true cheap - Everything is in stock and can be ordered in any possible combination   I've seen a few of these for other products as well. Things like sunglasses for example. I'd say stay away from it! And maybe reach out to the real theskylineshed and let them know this exists. I doubt there is much they can do about it, but still.   I don't know if they would actually take your money if you ordered something. Or whether it is just for collecting credit card details to scam otherwise. I'm not game or stupid enough to try it.
    • Hi guys has anyone ever bought from this website theskylineshed.shop?? Not theskylineshed.com as I’m aware there is 2 similar but different sites.     has anyone had any issues with theskylineshed.shop???
