does anyone know what would cause a battery to spark and go all smokey (on the negitive side) when trying to start a car?
happened on my drift car today, gonna get a new battery but not keen on it happening again.
fusible link corrosion possibly
-D
classic rally approaches 18-22 november.
anyone keen? can vouch its quality entertainment and some awesome cars.
i will prob hit the windy point area to watch again this year if anyone wants to come along. benefits of this spot is you can come and go as you please through blackwood while its going.
theres also the street party if anyone wants to get drunk :whistling:
Edited by Inline 6
John keen doing the tuning there Rubz?
Tires guys,
Rang wheelworx they said $200ea fitted for 255/35/18 which is what I have now which I am happy with,
Any other places I should ring to see if they can do cheaper? $200ea aint too bad though?
Edited by Weezy
Tires guys,
Adelaide Tyrepower, they can usually beat wheelworx prices.
Any idea where I can get a o2 sensor from anyone? Nissan want $192. Motor traders and repco don't have listings.
Cheers.
I'd like to replace mine too before my dyno tune. But at $192 ... ouch! :(
Do the Neo motors specifically need the $192 part? Can we wire in an EL O2 sensor?
you were just talking to the wrong people.
It was like 2 days before you told me about the KU36 you could get for cheap... or are you talking about the KU31 rears I bought from wheelworx?
Wayne, Dave is correct. 2 x KU31 265/35/18
Luke, not sure if this one is OK for the R34 as Ruby pointed out but it's a fk load cheaper than $192
http://www.gccorp.com.au/automotive/produc...products_id=168
pm sent dude.
need some basic info though, like the size youre hunting, and if you want something thats gonna have good grip and alright mileage or alright grip and good mileage.
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
