Beautiful. Cleaning my car for the first time lastnight at BP.. and my paint just starts peeling off. Owned it all of 4 days and I've got a 50 cent sized piece of paint missing and its basically down to the bare metal.
Who's got the hookups on resprays? Or knows roughly how much it would be to respray a hood
Edited by J-Dawg
from memory when Joe from Profinish was doing my car to respray the hood was $250. I did have a fair amount of other work done at the same time though...
<br />Anyone got some ideas on what I should do for the time being? To stop it rusting?<br />
<br /><br /><br />
It wont rust its aluminium. Maybe put some clear nail polish around the edge to keep it sealed and stop it getting worse.
Did it come off easily? My front bumper had paint peeled off pretty easily ages ago - had to have it stripped off then had the bumper prepped properly and resprayed. It must of had the bonnet resprayed in it's past and didnt get prepped properly...
Yeah.. giving it a good high pressure hose down.. but i was a couple of feet away (like I usually am) and the paint just flew off. But the whole front bar and hood as little touch up jobs all over it probably from stone chips
Damn - I would go and tear the guy that you bought it from a new one. Clearly he has completely dodged a paint repair to sell the car and done the nastiest lack of prep imaginable! Looks like blisters under the front grille too, so assume that will need to be resprayed soon too. Bummer.
Same thing happened to mine, took it to dazzlers after I'd got it... it had a couple of existing chips but when the sprayer hit them they flaked open
I wouldn't naturally assume its the ex owner, could have easily been someone in japan or any prior owner..
-D
Well I took my mums VZ commodore to a carwash cafe. They used a pressure hose and paint flaked off on the door handles a little bit. This is on a 1 owner car that was just over 3 years old.
I dont use the pressure washer on the Skyline. I still scratched it with the garden hose though :(
same thing happened to me with the high pressure hose flaking more paint away from a small crack in my front bar. i have never washed my skyline at those car wash joints since then. Those foam brush broom things are terrible too
scores ya points with the pitlane marshall ;)
I had nothing to do with that ... no influence whatsoever :(
All the cars I inspected in pitlane on the V8 weekend had black mesh ;) So no extra points awarded anyway.
Was a great finish to the race, pity about the pace car that finished Murphy/Skaife's chances but then that's racing I guess
A big ROR at those 2 in the same car.....that's like Ruby & Rhys going fishing together on a quiet Sunday afternoon. :D
Skaifey should've rigged his car to explode straight after the last lap cause Murphy reminds me of a couple of douches :D
About time i saw that car Matty!
Doesn't exactly resemble a skyline just yet.
Most people don't use house paint on their cars..
Thanks for the IC too :D
i thought u were referring to my intercooler, but then realised u meant iced coffee
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
